94 Civic LX-->distributor
The car was starting funny but it was starting.. So I decided to remove the distributor and inspect it.. took it off... and looked at it then I put it back... now the car isn't turning over.. Help??
Re: 94 Civic LX-->distributor (crxboi)
check to c if there's power when u start it...ie spark coming from the spark plug wires....my friend had n ignition coil go bad...took us 5 hrs to find out...
hope this helps...
u can check the spark by getting a paper clip and unwrapping just enough to where one side is still round. Stick the round end into the spark plug wire. Next hold it Very close to nething metal. Have a friend start the car...u should see many sparks....test every wire.
also it might b ur fuel...ur fuel filter is in the engine compartment, it has to lines going to it...one of them has a little bolt on top of it. take this bolt off and crank the engine. if gas comes out then u've got fuel, so ur problem is the ignition.
good luck
[Modified by gokuson, 12:24 AM 7/11/2002]
[Modified by gokuson, 12:25 AM 7/11/2002]
hope this helps...
good luck
