94 civic - fuse 15 keeps blowing
the dash lights gages and signal lights don't work the hazard ligts srs light and brights do work.
its the instr. 10 fuse i replaced and it worked for about a wk n now it only last about an hour anyone know about shorts and how to fix them.
Re: 94 civic electrical problem
10A dash fuse 15 protects the circuits for the cluster gauges and turn signals.
10A dash fuse 19 protects circuits for the cluster and climate control lights, as well as the parking and taillights.
Is fuse 15 or 19 blowing?
Re: 94 civic - fuse keeps blowing
Cluster lights - Pry dimmer switch out of the dash, unplug it, and then use a short piece of wire of paperclip to jump the red wire terminal to the black wire terminal in the connector. Do the cluster lights now work?
Blown fuse 15 -- With ALL electrical accessories off, turn the key from off to ON(II). Does fuse 15 blow? If not, switch the turn signals on. Does the fuse now blow?
Re: 94 civic - fuse 15 keeps blowing
In case anyone else runs into this. I found a back up light bulb that had the glass section broken loose from the brass base. That allowed the filament leads to short out when they bounced around when the car was in reverese. I replaced the back up lamps and the 10amp #15 fuse and everything works now.
[QUOTE=678gsr92;48933118]
my fuse 15 blows when I switch the turn signals on does anyone have an idea of what it can be?
O.G. triple O.G.
FOR THE 10 MILLIONTH TIME, YOU HAVE A SHORT ON THE LIGHTING CIRCUIT.
If you an aftermarket headunit, remove it and make sure the ORANGE ILLUMINATION wire is not being grounded out because it was not properly taped off. 99.99% of the time, this is the culprit.
jOnW89
33
02-20-2010 04:03 PM
lokoo23
20
09-12-2009 08:15 AM
lickety_britches
17
05-03-2009 12:42 AM
Jas0nEK
07-12-2008 11:35 AM
plusONE DC2
12-10-2004 05:10 PM
