94 Civic front end conversion!!!!!!!!!!!!
Old 12-24-2008, 10:03 AM
Bender C/F's Avatar
Default 94 Civic front end conversion!!!!!!!!!!!!
i have a 94 civic hatch and want the acura front end. What year/car do i get it from? does it bolt right on? i only need front quarters, front bumper, and headlights right?
Old 12-24-2008, 10:07 AM
Bender C/F's Avatar
Default Re: 94 Civic front end conversion!!!!!!!!!!!!
And Hood...
Old 12-24-2008, 10:33 AM
saywhat's Avatar
Can you be more specific? What Acura model?
Old 12-24-2008, 10:38 AM
Master Detailer
98civdx's Avatar
youll need more then that.
core support, bumper brace are the big ones
keep in mind core suport is welded in
Old 12-24-2008, 11:29 AM
dj theoretic's Avatar
Last time i saw something like this was 7 years ago when "fast and the furious ext...'' show imports where the thing... No so quite any more, but you will need core support and other things too. Creative, but it's your call
keep your car the way it is, trust me in the long run it will keep its top value if kept in good condition, thats if you ever sell it. Also how about a Ferio front End??? ill cost less way lessssss
go for it if you want
Old 12-24-2008, 11:34 AM
h2392si's Avatar
You'll need to much more than just that. It's your car but please don't do it, it's an insult to all Hondas when ricers do this. Just keep it OEM and lip/thread. Good luck either way.
Old 12-24-2008, 11:38 AM
H-T White Ops
NOFX's Avatar
I figure you're probably talking about an Integra, but how can we know what car you want it off of until you tell us what car you want it off of?
There are lots of threads on conversions though. It is not bolt on. You will need to cut the metal frame (core support) off the front of your car and weld a new one on.
You will also need to cut the fenders in half and weld them together.
This conversion is a huge pain in the ***.
Old 12-24-2008, 12:55 PM
rUMpLed4SkiN's Avatar
My friend has this conversion on his 94 hatch. He used a 99 usdm integra front end.
(imo the jdm integra type r front looks better on an eg) assuming you are talkin about an eg to integra conversion.
you don't need to "CUT" off your radiator support. But you do have to drill out the spot welds that hold it together (seen a lot of people cut the wrong stuff) once all the welds are drilled out it will come off with a little pull some times it even falls off so watch your feet.
YES you CAN bolt the new radiator support on. But it would be better to get it welded. I had a car like that the welds broke and i didn't have money to get it welded back so as a temporary fix I used bolts to secure the support untill I could get it welded and it held up extremly well.
The only parts that you can't just bolt up are the fenders. With the fenders you have to use a combination of the integra and civic fenders.You have to cut the fenders and weld the front of the integra fender (to line up with the bumper) to the rear of the civic fender (to line up with the door) the cut is not exactly in the middle so you have to look at it and line it up.
The parts used for the conversion are:
radiator support
bumper support
hood
bumper
fenders from both cars
headlights
corner lights/turn signals
and I am not sure on this part but I believe you need the headlight wiring also, but not 100%. you should get it anyways ( just the part that plugs to the lights)
just make sure you get all the parts from the same year and preferably off the same car.
There is a write up on here that a guy explains how to do a jdm integra conversion on a usdm integra using only bolts and zip ties. All of the steps are the same the only thing that is not covered is the cutting and welding of the fenders since it is integra to jdm integra.
Old 12-24-2008, 01:08 PM
boostedjdmdc2's Avatar
should have just bought an integra then. seems like far too much work to me atleast but hey if you want it try it. probably gonna be a lot harder to sell in the future, not many people like integra front ends on civics.
^ above post seems to have pretty much everything you need to convert. and dont just bolt your radiator support on, definitely not safe.
Old 12-24-2008, 01:31 PM
yea that bolt on was just a temporary thing, like a week or two just to hold the front together till I could get to my friend body shop I did the 99 conversion just cuz i had all the extra parts laying around and bought my 94 coupe for 600 with a smashed front end.....would change to eg front in a heart beat if i had the money for parts
Old 12-24-2008, 03:58 PM
Bender C/F's Avatar
How about that fiero front end?
Old 12-24-2008, 04:10 PM
soclean1k_JDM's Avatar
If anything I think ferio would be a down grade same thing just an uglier bumper. One of my neighbors had an integra conversion on his hatch looked clean and used one of the inner lights for ram air intake setup. To each is own. I have to agree with the saying if you want an integra front end you should have bought an integra. But its your car your choice.
Old 12-24-2008, 04:42 PM
arrocha87's Avatar
theres a crx with the integra front end in the dallas craigslist. it looks ok just too long of a front clip. i dont like the integra conversions on a civic either, but hey too each his own.
Old 12-24-2008, 07:44 PM
Bender C/F's Avatar
ok so the consensus says...dont bother...
Old 12-24-2008, 07:53 PM
H-T White Ops
NOFX's Avatar
There are still plenty of things you can do with the front end besides conversions.
Old 12-24-2008, 08:03 PM
CTR_B's Avatar
Here ya go Bro..
Edit: Heres one forsale on H-T
http://www.hondamarketplace.com/show...php?p=36787004
Bender C/F's Avatar
here's another question.... what about a DEL Sol front end? What would be involved in that?>???
Old 12-24-2008, 08:04 PM
Bender C/F's Avatar
very nice
Old 12-24-2008, 08:45 PM
jimmy o.'s Avatar
best thing would be to look around see what you like if your going to do a conversion dont half a$$ it if you do it will look like $hiT
but if it where me id leave it alone you already have the best looking civic front end (IMO) can look damn good given the right "touch"
Old 12-25-2008, 01:05 AM
yup hes right.... please dont do a front end INTEGRA its not cool. its wierd in the honda scene,,,,,, other than intagra jdm front ends on U.S integras. THATS COOL because its something that honda came up with for a reason.
racerx510
Honda Civic (2001 - 2005)
08-05-2012 12:33 AM
MauricioJDM
08-21-2011 01:35 AM
01em2slvr
21
06-17-2010 12:18 PM
jdm91CrxSi
03-18-2006 07:58 AM
civicmandx94
03-18-2003 11:35 AM
Quick Reply: 94 Civic front end conversion!!!!!!!!!!!!
