94 Civic EX Gauge Cluster Help Needed
Long time reader, first time poster.
Anyway. I seem to be having a problem with my 94 civic ex. Sometimes when I turn the headlights on, the lighting inside of my gauge cluster goes pitch black and won't work at all. I don't know if it's a short in the wiring or what, since I haven't pulled the whole cluster out and inspected it. (hoping someone else had this issue before and a solution)
Other times that it happens, if I push in the dimmer switch and hold it in for an extended amount of time the lights come back on.
any ideas? any solutions? thanks in advance
Re: 94 Civic EX Gauge Cluster Help Needed (josed190)
Could be as simple as loose/bad connections, to blown bulbs. No need to get a new one unless you dont feel like getting all of the above tken care of.
Re: 94 Civic EX Gauge Cluster Help Needed (bkmc24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 »</TD></TR><TR><TD CLASS="quote">Could be as simple as loose/bad connections, to blown bulbs. No need to get a new one unless you dont feel like getting all of the above tken care of.</TD></TR></TABLE>
That's be some weird **** if every single bulb went out at once
i use to have the same problem... same car to...
i found out it was the switch that turns the lights on/off. like if it happens just slowly move the switch for the lights towards you and itll light back up... one day i just hit it and it stopped doing it, lol weird.. but yea actually worked...
Re: 94 Civic EX Gauge Cluster Help Needed (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony »</TD></TR><TR><TD CLASS="quote">
That's be some weird **** if every single bulb went out at once </TD></TR></TABLE>
wouldnt surpise me tho. Hondas do some crazy stuff, hence me still not up and running lol
my bet would be back connection tho
Kurrupted_Squid
10
02-13-2013 08:22 PM
jdmsteveo05
12-31-2006 01:04 PM
crxspoonb18c5
11-15-2006 08:00 AM
