94 civic d16y7 no power help me!!!!
Old 07-18-2012, 05:04 PM
V-Nonyak's Avatar
Default 94 civic d16y7 no power help me!!!!
Hello ht I need your help I have a
1994 civic coupe
D16y7
Problems
Car idles perfectly but once it's warm I take it around the block and it has no powere when I punch it and also has no powere when going up hills when I pull the throttle cable it sounds like its ether sucking in too much air or not enough and when I just lightly push the gas it drives fine!? Help!?
Old 07-18-2012, 05:18 PM
EJ8_Man's Avatar
Default Re: 94 civic d16y7 no power help me!!!!
It sounds like something is obstructing your throttle body, check your air intake, filter, and throttle body.
Old 07-18-2012, 05:51 PM
thepolishman's Avatar
id start to check with fuel pressure and flow, when was the last time you changed your fuel filter? could be plugged?... fuel pump taking a crap, maybe coils arking under load, check cap rotor, all the basic tuneup crap
Old 07-18-2012, 06:07 PM
V-Nonyak's Avatar
Thanks for the fast reply. The fule filter and pump were changed yesterday same with injectors and still no luck I will check the TB in a little bit any ideas wht els it could be..?
Old 07-18-2012, 06:11 PM
V-Nonyak's Avatar
I just advanced the timing and it made a huge difference it got a lot better but u can still feel the mother is like not giving all its power like its holding it back
Old 07-18-2012, 06:20 PM
well im glad to hear it starts to run better, maybe check spark plug gap? if they are undergapped then your not burning all the fuel you need and advancing the timing would allowing a little bit of a longer burn time...idk. how many miles on the thing?
Old 07-19-2012, 06:48 AM
V-Nonyak's Avatar
I'll be checking gap today. And not sure on miles motor was just put in by my brother and the guy we got it from said there's like 140000 I think but who knows. Lol
Old 07-19-2012, 04:59 PM
V-Nonyak's Avatar
checked the gap changed the map sensor changed the dizzy and it runs good now but you can still feel its still slow idk if maybe I'm just used to my turbo b18 or if this thing is still sluggish
Lol
Old 07-19-2012, 06:04 PM
The Grumpiest
grumblemarc's Avatar
Just verify the timing. And you have a Y7. They are painfully slow. Especially up hills.
Old 07-19-2012, 07:53 PM
jbpnoman's Avatar
The only time a Y7 isn't slow is when you drop if off a cliff.
Old 04-10-2013, 11:37 PM
switchblade94's Avatar
Whats the dizzy I must know as im having samenproblems with the one I just bought tonight....im getting new plugs wired xap and rotor tomorrow along with fuel filter and doing an oilchange and ill do the map sensor too andnhow can I make this engine a vtec??
Old 04-11-2013, 01:31 AM
Technical Hero
HondaPartsHero's Avatar
Distributor. It really helps to list your year, make, model, ecu and any other info like is the check engine light on, have you done a tune up, etc. For VTEC search for "mini me".
Old 04-11-2013, 03:10 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
I would start a new thread next time instead of bumping an old thread, thread title should contain important information not just "HELP PLEASE". Also every thread you start should have vehicle and engine information, "94 civic, maual, d16y7.....etc"
elnene_14
08-25-2013 10:55 AM
si del sol 94
18
09-16-2009 07:39 PM
wanderinglost
09-26-2008 05:57 AM
98TypeSH
04-26-2004 10:25 AM
Jonathan_ED3
01-04-2003 08:50 PM
Quick Reply: 94 civic d16y7 no power help me!!!!
