94 civic abs problem????
Old 09-03-2007, 01:08 PM
vtecman4500's Avatar
Default 94 civic abs problem????
i lowered my car and now right when i start to drive get to about 5 mph the abs light turns on... the abs wires arent cut or anything... any ideas?
Old 09-03-2007, 03:05 PM
keemosaki's Avatar
Default Re: 94 civic abs problem???? (vtecman4500)
did you unplugg your battery for any reason?
Old 09-03-2007, 03:51 PM
Default Re: 94 civic abs problem???? (keemosaki)
nope i sure didnt...
Old 09-03-2007, 03:54 PM
Thateguhate's Avatar
i dont think it has to do with the drop unless one of your wires could be snagged by the rear LCA's.. if you tugged on anything back there it could be it.
Have you checked your brake fluid level yet, if your even a lil short sometimes it will trip the sensor.
Old 09-03-2007, 03:56 PM
Default Re: 94 civic abs problem???? (Thateguhate)
when i was doing the rear i was tuggin on them a bit... expletive i wonder if i can fix it.. its not ripped or cut or disconnected....
havent checked da fulids yet though.... hopefully thats it
Old 09-03-2007, 04:00 PM
turn the car on, and play with the cable that wraps and connects to the LCA, if it trips the sensor with even the least amount of play then thats probably the issue at hand.
Old 09-03-2007, 04:26 PM
NastyHabitzCRX's Avatar
you probably have a bad wheel sensor. there is info on here how to pull the code and check for minor issues
Old 09-03-2007, 04:29 PM
Default Re: (NastyHabitzCRX)
how do i do that?
so u think i fucked it up when i lowered it or sumshit?
Old 09-03-2007, 04:45 PM
Default Re: (vtecman4500)
bad wheel sensor?? first ive heard of it...
for some reason mine always acts up in the wintertime..mostly when its cold, and raining..
Old 09-03-2007, 10:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecman4500 &raquo;</TD></TR><TR><TD CLASS="quote">how do i do that?
so u think i fucked it up when i lowered it or sumshit?</TD></TR></TABLE>possibly pull the code
MikesEJ1
03-25-2013 03:28 PM
citrus3000psi
10-26-2005 03:47 AM
monkijunki
09-24-2004 05:41 AM
TerribleOne
03-19-2003 10:59 AM
Nighthawk GS-R
08-05-2001 11:04 PM
Quick Reply: 94 civic abs problem????
