94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
Old 12-26-2006, 10:28 AM
  #201
digital sol's Avatar
Default Re: (Bostek)
del sol wiring diagram?????
digital sol is offline
Old 12-26-2006, 06:30 PM
  #202
BlueIntegraBoy's Avatar
Default Re: (digital sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote">del sol wiring diagram?????
H-T is loading funny at work, so in response to your PM...
I dont have a diagram for it, but the Del Sol cluster uses EK/DC plugs I think. If you had a pic of the plugs with the wires, I could figure it out.
BlueIntegraBoy is offline
Old 12-31-2006, 10:38 AM
  #203
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
1993-1995 Del Sol Cluster Wiring Diagram
Old 01-01-2007, 08:10 PM
  #204
pkdog167's Avatar
Thanks to BlueIntegraBoy Without his diagrams, I'll never do it . I have my 94 integra cluster into my civic. Followed his diagrams and everthing works great. My civic is an auto and I have a auto integra cluster too. They are color match, but two ain't and I never figure it out what they are, and my N is not working now and I check the bulb already. But o well I don't need it.
As for the fitment. It fit like **** without trimming. I trim the cluster's top (where the gay thing stick out ) and the plastic thing that in the middle of the metal where it hold the civic cluster. (Don't know how to say it), and I didn't cut my bezel, in case I want to put my civic cluster back in. And force the cluster in and it will hold up good.
And I don't have the fuel gauge problem, it works perfect.
I'll take picture some day....
O ya, there is a big gap on the bottom. But I will cover it with plstic some day..
pkdog167 is offline
Old 01-01-2007, 08:41 PM
  #205
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks to BlueIntegraBoy Without his diagrams, I'll never do it . I have my 94 integra cluster into my civic. Followed his diagrams and everthing works great. My civic is an auto and I have a auto integra cluster too. They are color match, but two ain't and I never figure it out what they are, and my N is not working now and I check the bulb already. But o well I don't need it.
O ya, there is a big gap on the bottom. But I will cover it with plstic some day.. </TD></TR></TABLE>
One of the left over wires is probably the N light. Here are the wire colors from Helms.
<U>Integra A/T Gear Position Lights</U>
P - Green/White
R - Green/Red
N - Green
D4 - Green/Black
D3 - Green/Blue
2 - Green/Yellow
1 - Light Green/White
<U>Civic A/T Gear Position Lights</U>
P - Green/White
R - Green/Red
N - Green
D4 - Green/Black
D3 - Green/Blue
2 - Green/Yellow
Edit: All wires should match up.
Old 01-01-2007, 09:49 PM
  #206
pkdog167's Avatar
well i got two wire left over, one light green/black and yellow/white from integra cluster, and green, yellow, red and red/black.
pkdog167 is offline
Old 01-01-2007, 10:02 PM
  #207
pkdog167's Avatar
and my D4 is always on and off when I'm in D4. Just wondering if it's like that or not..
pkdog167 is offline
Old 01-05-2007, 08:04 PM
  #208
bigcalidave's Avatar
Your A plug is the B plug, and vice versa.. According to honda, shopkey, etc..
bigcalidave is offline
Old 01-05-2007, 08:05 PM
  #209
And why not put an S2000 cluster in??
Old 01-06-2007, 12:24 AM
  #210
Default Re: (bigcalidave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigcalidave &raquo;</TD></TR><TR><TD CLASS="quote">Your A plug is the B plug, and vice versa.. According to honda, shopkey, etc.. </TD></TR></TABLE>
The exact designation isn't key, just using it as a quick reference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigcalidave &raquo;</TD></TR><TR><TD CLASS="quote">And why not put an S2000 cluster in?? </TD></TR></TABLE>
I was contemplating it, but I don't have the funds right now. Plus I would have to get rid of my Spoon EG cluster.
Nice work with the S2K speedo converter. If I had around $400-450, I would do the conversion.
Old 01-07-2007, 11:50 AM
  #211
pkdog167's Avatar
Everyone want a s2000 cluster :D
pkdog167 is offline
  #212
pkdog167's Avatar
Default Re: (pkdog167)
bump for s2000 cluster
pkdog167 is offline
Old 01-15-2007, 09:31 AM
  #213
gottalovethe4door's Avatar
good stuff
gottalovethe4door is offline
Old 01-15-2007, 02:08 PM
  #214
After more than two years, I decided to revise and refine the diagrams to be a little bit more specific. I included the other plugs that connect to the cluster except for the automatic gear indicator lights.
Old 01-17-2007, 03:24 PM
  #215
at the jetties fishin'
stackz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">After more than two years, I decided to revise and refine the diagrams to be a little bit more specific. I included the other plugs that connect to the cluster except for the automatic gear indicator lights.</TD></TR></TABLE>
might want to upgrade it again lol.
I just got done about 10 minutes ago tossing an 01 teg cluster into my 93 (like the 7th teg cluster swap I've done) and this was my first 01 cluster and some of the wires are different.
mainly the D connector
D1=pink=immobilizer input
D2=white/green=constant 12v power for immobilizer
D3=empty
D4=Yellow=Ignition
D5=Pink=Maintainence
D6=red/blue=Cruise input
D7=Black=Ground
D8=Yellow/green= temp gauge
D9=white/blue=Battery Light (--)
D10=empty
D11=yellow/red=Low Oil input
D12=green/orange=check engine
D13=blue=tach
as you can see, the second half of the connector is pretty much the same but acura apparently redid the first half to make room for the immobilizer light in the cluster and swapped some stuff around as a result.
I'm actually making use of the immobilizer light by wiring my aftermarket alarm LED light into it as well as splicing from the alarm's constant power so now my alarm runs the immobilizer circuit
my info is accurate as I pulled it straight from mitchell-on-demand and well, everything works
just fyi
stackz is offline
Old 01-18-2007, 12:36 AM
  #216
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">
D3=empty
D4=Yellow=Ignition
D7=Black=Ground
D10=empty
D13=blue=tach
just fyi</TD></TR></TABLE>
Thanks for the info, I don't have a 00-01 Helms and was wondering about the immobilizer wiring.
Old 01-19-2007, 12:12 PM
  #217
Oh, is all this stuff based off of helms manuals?? Damn. If you need real specific diagrams, ask me, I have shopkey...
Old 01-19-2007, 05:28 PM
  #218
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigcalidave &raquo;</TD></TR><TR><TD CLASS="quote">Oh, is all this stuff based off of helms manuals?? Damn. If you need real specific diagrams, ask me, I have shopkey...</TD></TR></TABLE>
Yeah, I had a diagram before, but refined it with Helms. I mean, it's pretty specific. Dave, can you send me a 00-01 Integra?
Old 03-21-2007, 01:32 PM
  #219
rayscrxx's Avatar
Default Re: (BlueIntegraBoy)
hay i did the dash swap in my 92 cx hatch n i have a prob with my trunning signale n headlites like wen i trun the key on the running lites come on n stay on but i have no trunning signals or headlites can some1 help me ....email is honda89ray@aol.com or aim is honda89ray
rayscrxx is offline
Old 04-18-2007, 09:10 AM
  #220
vizeta's Avatar
I did 96 spec JDM ITR cluster on my 98 civic EX coupe. it works perfect. thx alot BlueIntegraBoy. But now, I gonna find out how to hookup SRS and ABS lights to extenal LED.
vizeta is offline
Old 04-18-2007, 10:13 AM
  #221
Default Re: (vizeta)
Try bending the mounting brackets a little foward to minimize that top gap. Looks good though.
Old 04-19-2007, 08:40 AM
  #222
vizeta's Avatar
yep, will work more on the fitment. I may custom make a carbon filber trim later.
vizeta is offline
Old 04-21-2007, 10:20 AM
  #223
weezee456's Avatar
that diagram for the 1996-2000 into 92-95 would that work the same if i was going with a 99 si cluster
weezee456 is offline
Old 04-21-2007, 03:58 PM
  #224
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (weezee456)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weezee456 &raquo;</TD></TR><TR><TD CLASS="quote">that diagram for the 1996-2000 into 92-95 would that work the same if i was going with a 99 si cluster</TD></TR></TABLE>
yes
Old 04-23-2007, 07:37 AM
  #225
vic000's Avatar
Hi bro blueintegraboy, i just got a 99 ITR cluster.
i'm driving 92 civic, when i took out my original meter, look at the connectors, the wires' colour is same as you mentioned, but the location is different. so i tried to follow the pin location, after all wire done, the itr meter is not working at all, no power, no light. shall i undo the wiring and connect them again by following the colour code?
btw, the ITR cluster i took it out from a 99ek, it's fully working.
thanks
vic000 is offline
Quick Reply: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
