93 Sol, front end creaking
Got a 93 Del Sol, all stock.
When braking, turning, and downshifting I have some creaking/ groaning coming from my front end. It isn't constant, seems to maybe fluctuate with changing weather; more constant in the cold and rain.
Just had a friend change my lca shock fork bushings on Sunday,
my cv boots look good, my ball joints don't look terrible, and my engine mounts are good.
Any ideas or suggestions as far as where else to look for the noises?
Re: 93 Sol, front end creaking
did you replace the damper fork bushings or the lower arm bushings? when my lower arm bushing went it would make a bad creaking/knocking sound from the front end. another way to check is to get a can of PB blaster or a similar lubricant and spray all the suspension joints one by one to narrow down where the noise is coming from.
Is the sound coming from one side (driver/passenger)? Is it louder when turning left vs right? did your friend lubricate the bushing(s) he replaced?
btw I would not spray PB blaster on all of your rubber bushings, as it may degrade the rubber over time. hit suspect bushings with silicone lubricant.
Last edited by hondatek614; 04-03-2015 at 09:43 AM. Reason: addressing poor advice given in prior post
I have the same creak on my 93 Delsol Si, I am rather sure its my front sway arm bushings. Not sure if you have an S - Si so not sure if you even have a sway bar.
DelsolVted
08-10-2011 06:26 PM
ShinotakuX
07-20-2009 06:06 PM
htscottm
10-12-2007 05:58 AM
