93 si hatch build!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hey guys i bought this hatch for 100 and wanna know your opions. so currtly putting a jdm d15b vtec in it now the motor has compression on every cyclinder 1)200 2)200 3)215 4)200. now are these number good and what do they mean?
thank you guys.
thank you guys.
Stouts 'n' Scotch
Re: (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 »</TD></TR><TR><TD CLASS="quote">Wow, a lot of work on your hands. Good luck with it, all she needs is love, and money.</TD></TR></TABLE>
Yikes! Good luck, seriously.
Guest
Posts: n/a
I wouldn't worry bout it for now man if your running a low budget, but if you like, you can get OEM quarter panels from almost anywhere for the 92-95 civic hatchback.
The Q-panel can be installed by any body shop without breaking the bank as long as you shop around for the best price on a Q-panel for your hatch, once thats done, the car will look gorgeous along with some paint.
Guest
Posts: n/a
O btw your compression looks good to me. I seen b18's with lower compression then that which ran perfectly fine, so if you can vouch for it being a running motor that you bought and the compression numbers are that good then im sure it will be fine.
Stouts 'n' Scotch
Re: (efking1985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 »</TD></TR><TR><TD CLASS="quote">yea man what u think ill do in the 1/4 mile with this jdm d15b and light flywheel and i/h/e ?</TD></TR></TABLE>
I think you'll need some front tires before you start worrying about track times.
Re: (efking1985)
For 100 bucks it's worth a try and for that money you can always turn it into a (relatively) cheap track car. And as a track car I totally would NOT worry about that rear panel. I'd just take out as much of it as possible with a hammer and then just paint the whole car black all by yourself. Good enough for a cheap trackcar
