93 Hatch Si starting problem
Old 10-01-2003, 04:44 PM
Nocturnal's Avatar
Default 93 Hatch Si starting problem
As I turned on my car today it turned on but it took a while. At first it didn't even want to turn over at all. Then it kicked in and it whined like it was dying out. Do you think it could be the starter or the battery?
I bought the car second hand from someone who claimed to have taken good care of the car. The car has about 130k miles on it. Roughly 10k is from me.
I've done routine oil/plug changes etc.
Again, the problem is that it whines when I turn the key. Sounds like it doesn't really want to start but eventually starts up.
What could be the problem?
Old 10-01-2003, 04:48 PM
TrickHonda98's Avatar
Default Re: 93 Hatch Si starting problem (psychotic)
The starter miight be going bad, but also check your fuel filter and air filter, the engine might be gasping for gas and air, and a clogged fuel filter can cuase the car to do that.
Old 10-01-2003, 04:49 PM
Nocturnal's Avatar
I noticed that with the a/c full blast it often chokes or sounds like it's gonna stop running but blasts through it some how. It's weird. Do you think it could be the fuel filter?
I recently checked my air filter and it was clean.
Old 10-01-2003, 05:19 PM
Nocturnal's Avatar
Any other ideas?
Old 10-01-2003, 06:52 PM
2lua's Avatar
what do you mean by whine noise? like trickhonda said it could be your starter going bad. take it to autozone or napa so it can be test to see if your starter is bad or not.
Old 10-01-2003, 07:19 PM
dunkd's Avatar
Default Re: 93 Hatch Si starting problem (2lua)
go to autozone
Old 10-01-2003, 07:44 PM
HXvtec's Avatar
Default Re: 93 Hatch Si starting problem (dunkd)
yea check your starter but also check your fuel. it may not be that but if you have a fuel leak it might take a while to start up. thats what happen to me. does it seem to waste a lot of gas?
Old 10-01-2003, 07:50 PM
Nocturnal's Avatar
No it doesn't waste gas. It only started happening today.
As far as the whining noise... it turns over and starts but it takes a while. Usually I turn the key and it'll start up. Now I turn the key and it'll make that turning over noise but kinda in slow motion and then start up eventually.
Old 10-01-2003, 10:25 PM
Nocturnal's Avatar
TTT
Old 10-01-2003, 10:47 PM
BatuKing's Avatar
Default Re: (psychotic)
Braddah.. dakine da bugga is da battery.
Go call around da local auto places and check to see if they can check da thing for ya. If not go to Pearl Ridge and go to sears to check da battery ( if sears is still there I havent been back home there in 7 years )
Dont forget to eat da rice and da spam too
Old 10-01-2003, 11:06 PM
New User
IWearMyKswiss's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic &raquo;</TD></TR><TR><TD CLASS="quote"> Now I turn the key and it'll make that turning over noise but kinda in slow motion and then start up eventually.</TD></TR></TABLE>
this makes me think its the starter,..get the battery and starter checked
Old 10-01-2003, 11:10 PM
ERA
ERA's Avatar
Default Re: (WiDeBoDyEK)
If none of this fixes, check your timing.. belt might have skipped a tooth.
Old 10-01-2003, 11:15 PM
Nocturnal's Avatar
Default Re: (BatuKing)
Ok buddy. You should have seen, there was this huge special broadcasted over all the major channels in regards to your name LOL. The problem is HUGE over here.
Old 10-01-2003, 11:17 PM
ERA
ERA's Avatar
Old 10-02-2003, 12:27 AM
integlspwr01's Avatar
like everyone said, could be starter or your main relay going bad or not enough gas in your gas tank.
I went through to main relays already soo i know how it feels etc....
shoots
Old 10-02-2003, 01:57 AM
be professional
Targa250R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic &raquo;</TD></TR><TR><TD CLASS="quote">No it doesn't waste gas. It only started happening today.
As far as the whining noise... it turns over and starts but it takes a while. Usually I turn the key and it'll start up. Now I turn the key and it'll make that turning over noise but kinda in slow motion and then start up eventually.</TD></TR></TABLE>
If it's slow turning over then it's probably your battery. Battery should be replaced, and if the problem persists then it would be a good idea to have the alternator checked to make sure it is generating enough power (i.e. to charge the battery) and also check the starter.
Fuel delivery problems, main relay, and timing belt would not cause a slow crank.
Old 10-02-2003, 03:13 AM
93CivicSI's Avatar
Take your car to autozone and let them perform an electrical system analysis - then you will know what to spend your $$$$ on to fix it.
Old 10-02-2003, 10:30 AM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic &raquo;</TD></TR><TR><TD CLASS="quote">Ok buddy. You should have seen, there was this huge special broadcasted over all the major channels in regards to your name LOL. The problem is HUGE over here.</TD></TR></TABLE>
Yea I left da islands because I almost got busted for it too smoking it was bad but selling it also was worse
da islands is getting betta or what? I gotta go back in july for a wedding I can go back by then da HPD cannot do anything now
Old 10-02-2003, 07:22 PM
dunkd's Avatar
get in the zone... autozone!
Old 10-03-2003, 12:37 AM
Nocturnal's Avatar
Default Re: (dunkd)
We don't have an Autozone in Hawaii LOL. We only have a Checkers and Sears.
Old 10-03-2003, 10:09 PM
BatuKing's Avatar
yea.. go to checkers.. ask them to see if they have a vat-40 or something similar to test da battery so you know that bugga is not the problem
Old 10-03-2003, 11:09 PM
underrated's Avatar
Almost any service station with a mechanic will do it for you. I think even sears will do it.
Derek Persons
05-29-2016 09:46 PM
StolenTeg
Honda Civic (2006 - 2015)
10
07-02-2009 07:43 PM
twr176
12
07-06-2008 08:18 PM
bignosewhipper
16
07-03-2008 05:38 PM
supertouch
Honda Civic (2001 - 2005)
11
07-20-2007 10:19 AM
Quick Reply: 93 Hatch Si starting problem
