93 ex coupe chassis wiring diagram needed!
Hi all,
I'm in need of the main chassis wiring diagram for a 93 ex coupe. I assume all 92-95 civic would be the same. It's labeled "fuel injected system diagram" in the honda manual.. one of the last pages. I've found the manual all over the web, but everyone has the same .pdf and the scan is too distorted to determine the wire colors. Thanks in advance for any help u can provide.
Re: 93 ex coupe chassis wiring diagram needed!
why not just look up the injector pin's on the ecu i believe they are red brown yellow and blue. that will tell u what color and injector each go to. the other wire is just a common wire color usually a yellow and blk stripe that all go to ground
i don't just need the injector pinouts... "fuel injected system diagram" refers to the schematic that I need from the honda service manual. The previous owner hacked up the main chassis harness when he tucked the engine compartment harnesses. I need a reference to double check that I've got everything back where it should be. Thanks for the quick reply
Eldred
07-12-2017 09:42 AM
