93 del sol s, 2 si conv. throwing code idk, it keeps flashing?? need help...
ok, got a code 43, what to do f/m here???????????
all right, it was a d15b7 s model, i had another 93 si that some drunk driver hit, it had a semi built d16z6, my si was pretty quick so i just swapped everything, p28 ecu, the whole harness, all is hooked up and seems to be right, ive had people look at it, they also cant figure it out...hell the auto 2 5 spd swap was easier,this is the cars problem, sometimes it runs great, i can tell vtec is not working any, but sometimes it starts skiping bad unless i drive at like 4000 rpm, then it throws a cel and runs fine again. but when i scan the ecu, by makeing that connection by the ecu, i know im checking it right, but the light will flash as long as you will let it, so no code, or does this mean something, i havent ever read a page about anything like this one, if i could get a real code, i could trouble shoot. but as ya see its kinda hard 2 do like this, any help or ides welcome, thanks mike ok i finaly got code 43. what should i do from here, can this make v tec not work? idk bout that, any help welcome.....
Modified by gotsol607 at 8:51 PM 8/16/2007
grinch559
05-23-2012 07:05 PM
dohcdelsol93
10-27-2004 10:27 AM
