93 del sol heat not working
Old 12-22-2012, 09:19 AM
faze07's Avatar
Default 93 del sol heat not working
The heater in my car isn't working. The fan is blowing air, and the a/c works fine, but I'm not getting any hot air coming out of the vents when I have the temp slider all the way to hot. Any help would be appreciated.
Old 12-22-2012, 09:42 AM
B20DelSol's Avatar
Default Re: 93 del sol heat not working
Check the heater valve on the heater hose. It is located above the rear engine mount, right against the firewall. Also, you may need to bleed your coolant system in case air has gotten into the hoses and is blocking the coolant.
Old 12-22-2012, 10:19 AM
Emeraldbomber's Avatar
^ does your car warm up to normal operating temp?
Old 12-27-2012, 08:03 PM
thomasEG's Avatar
theres a cable that runs from the slider in the ca from cold to hot that goes to valve to the heater core see if its on or broken its located passenger side fire wall
Demented Sol
11-15-2012 12:46 PM
shady3260
08-09-2012 03:04 PM
nitewolf
15
10-28-2010 05:15 PM
Since 1983
04-29-2008 12:23 PM
R249
01-24-2003 11:10 AM
Quick Reply: 93 del sol heat not working
