93 del sol/d16z6 engine - no start, no fuel, no spark
So frustrated
So far I have replaced the main relay, rebuilt the dizzy (icm and coil), all fuses are good. When I jump the wiring harness for the PGM relay the fuel pump primes. There is 16V going to the harness to the fuel pump. Clueless as to why it doesn't turn on. There is power going to it and the relay is new, should work?
I also cleaned the thermostat ground. The ecu is a p28 and I switched up the ecu to one from my teg which is a p08 modded to a p28 (which should work?)
I don't want to tow this car to a mechanic yet, still hopeful.
Any suggestions?
Any suggestions?
Re: no start, no fuel, no spark
So frustrated
Any suggestions?
Any suggestions?
And why is your system voltage (16V) so high? Battery voltage should be about 13V.
main relay was bad (bench test) and yes the distributor was a guess
and yes did both jumps and it primes
I read voltage from the harness that leads to the fuel pump. maybe its a bad ground?? Fuel pump doesn't prime on its own.
I found a fuel pump circuit diagram step by step so I ran through the circuit and everything checks out fine (no open circuits, continuity good). It might be the ECU, I am going to borrow one and see what happens. Although, the SOHC del sol has a p28 and I tried a p08 modded to a p28 (from my DOHC integra) already and it didn't run. Would the car not even start with the other ecu just due to a compatibility issue?
This^ test tells you that the fuel pump ground is fine.
This is worth trying if you have access to a known good ECU, though there are more tests to do before you should conclude the ECU is bad.
To avoid wasting time suggesting tests that you've already done, give details about these^ specific tests and how you did them.
I ran through a test I found online: checked for continuity between black terminal 2 and body ground. Measured voltage between YEL/WHT terminal 1 and body ground. Measured voltage between BLK/YEL terminal 5 and body ground (ignition switch on). Ignition switch in start position measured voltage between BLU/WHT terminal 6 and body ground. Checked for continuity between GRN/YEL terminal 8 and A7. Measured voltage between A23 and A25,B1. Measured voltage between A7 and A23.
Re: 93 del sol/d16z6 engine - no start, no fuel, no spark
Anyone have a clue why I would be reading 9V from the map sensor to the thermostat ground when it should only be 5V? Does that sound like a shorted wire somewhere?
If anyone is going through the same problem...
Finally figured out what the issue was the ecu ground wire itself was bad. The relay was also blowing a fuse.
video_voide
01-11-2018 08:47 AM
WhiteSlips
26
07-14-2013 07:51 PM
sohctodohc
41
09-09-2010 04:06 PM
