94 Civic - popping noise when turning left
Old 03-30-2011, 06:32 PM
ev94eg's Avatar
Default 94 Civic - popping noise when turning left
i got a 94 civic 4 door and when i cut my wheel almost all the way left something pop but it doesnt do it when i cut it right, it has new tie rods also. any help would be appreciated.
Old 03-30-2011, 06:52 PM
Former User's Avatar
Default Re: HELP
Please read the stickies at the top. Thread titles must be subject specific - edited.
You may have a bad axle.
Old 03-30-2011, 07:14 PM
ev94eg's Avatar
Default Re: 94 Civic - popping noise when turning left
thats what i was kind of thanking. and thanks btw for changing that for me. wont happen again
Old 03-30-2011, 07:20 PM
ElliotSiR's Avatar
Check your ball joints along with the axles. Ball joints should have no more than a nickle's thickness worth of play in them. The proper way to check them is to lift the car slightly off the ground, put a pry bar between the ground and the tire, and pull up on the tire. If it is your ball joints, fix them before you drive the car again, if a ball joint goes out, you will crash. How do I know? Seen it happen in person.
Old 03-30-2011, 07:36 PM
Seagull Management
94EG8's Avatar
They shouldn't have any play in them. Period.
Old 03-30-2011, 08:36 PM
ElliotSiR's Avatar
Zero play is considered optimum, but the thickness of a nickle is considered acceptable. If that's not the case then ASE needs to edit their test answers.
Old 03-30-2011, 10:22 PM
Queasel's Avatar
Check your ball joints. I have a 92 civic hatch and mine was doing the same exact thing but it was when I turned the wheel to the right. I changed the ball joint and it fixed the poping problem its worth a shot.
Old 03-31-2011, 04:47 AM
Seagull Management
94EG8's Avatar
Some makes (Ford comes to mind) allow for a small amount of play. But a Honda balljoint should have none.
Old 03-31-2011, 07:35 AM
matt824's Avatar
same thing happened to me, it actually turned our to be a bad bushing in the front lower control arm, went and bought the energy ones and it fixed it
Old 03-31-2011, 10:01 AM
shogee's Avatar
Ase is talking about gm truck specs,
picthis1
02-01-2012 08:32 PM
barone
09-05-2011 07:41 PM
bjones
09-13-2007 09:07 AM
CleanHatch
10
10-23-2005 09:52 PM
92BlackSi
12-20-2003 05:49 AM
Quick Reply: 94 Civic - popping noise when turning left
