93 civic si radiator support
ok my radiator support is all bent so i wanna buy this one here http://cgi.ebay.com/ebaymotors/NEW-R...Q5fAccessories
I just wanna know if this whole piece is spot welded anywhere or is it bolt up to the chassis?? Thanks |
Re: 93 civic si radiator support
your going to regreat buying that.... its junk, i have a ebay support in my car and they are junk.
the core support is spot welded. |
what do you recommend?? i need one because my hood won't flush after my car was hit in the passengers side so i need a good one.
the ebay ones are problaly made in the same factory as the ones bought at a local parts store.
Call you local parts store and see if they can order you something, i bet it will be cheaper than that oneon EBAY. They are spot welded you need a 5/16" drill bit and a chisel. along with a welder to tack the spots back together. alot of work but if you know what your doing its a simple breeze. i've done these many times before if you have any questions just ask. |
^^ its the same quallitly.
i have 3 core supports sitting in my back yard for 2 from ebay,and 1 from an auto parts store, they all suck! look for a used oem one. |
but when you get aused one it'll problaly be all hacked to shit because they got to rip it off.
so should i just stick to a on from a local store?? anything will be better than mine, and i don't really plan on doing it, not that i can't but i don't have the tools and thanks for all the help guys.
