93 Civic - pulled plug wire, now won't start
i have a 1993 civic ex couple and my 15 year old nephew pulled the number 1 spark plug wire off while the car was running i tryed 2 hurry up & put it back in but the car cut off & ive tryed a million of things trying to get it 2 start it dont get no spark anymore someone please help if you have any ideas or been through it
Re: going crazy
Pulling a plug while the engine is cranking or running generally blows the coil inside the distributor.
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post.
Please familiarize yourself with the stickies at the top.
Title edited.
Title edited.
Re: 93 Civic - pulled plug wire, now won't start
ur right my bad but yes it was on thanks 4 title change im new to this if it had to do with body work no problems i dont c where the igniter is i got hanes & clilton books and nothing puzzles me so much!!
my bad yeah the igniter unit is the icm right ? it read 2.7k the book call for 1.1-3.3k that was the resistance between the white&blue and blue wires but i pulled it out & un hook all 4 wires i've checed all fuses and they r all good
pulled plug wire running now wont start
i've done everything i can think of i checked the coil,icm,all fuses.i also bought all new ngk plugs & wires, new distributor cap & rotor button
im new & tring 2 sticky my post i went 2 faq & did what it said but it dont say sticky by my post
do you hear the main relay click wen u turn the key?
i had this same exact problem, i pulled off 2 ignition wires to kill then engine and ended up frying my coil.
make sure the new coil you put in is good by checking resistances with an ohm meter.
how do you know the icm is good? u can pull it out and have it tested at almost all auto parts stores.
did you use a test light or multimeter to test the fuses? make sure 10000000 times that all fuses are in and that theyre good, i accidentally pulled 1 out and forgot to put it in, then i changed my faulty part (coil) but still didnt have spark. i wasted a day testing connections and the main relay etc etc...only to find that i forgot to put a fuse back in
in my 1999 civic, when you touch the negative screw goin 2 the coil with a test light and crank the engine you should see the light flash on and off, if you dont see this then the icm isnt getting its input from the ecu.
did you check the distributor? look in your haynes manual and i think there should be a sectino that tells you how to test the sensors in the distributor, basically you measure resistances across terminals at the connector that goes to the dizzy.
download the factory service manual for your car and troubleshoot. ull find ur problem.
i hear the fuel pump come on when i turn the key 2 on,the black & yellow wire is power but the white & blue wire dont show any power thats w/ a test light.but then i used a multimeter 4 resistance & instead of putting mm tips on wire i put them straight 2 the terminals i did have 2 replace the coil im at a loss what 2 do ?????????????????????????????????????
hey how r u if u dont mind i did add u as a friend but on a different note i was wondering if u would tell me what book u got that pic. out of, i try 2 get all books i can & manuals
gl89
01-17-2019 08:57 AM
SVOHK
06-18-2015 08:46 PM
PapaMoose
27
11-19-2011 03:00 PM
Bailhatch
08-05-2004 10:13 AM
