93 civic d16z... NITROUS???
Old 05-03-2009, 08:40 AM
bsk211105's Avatar
Icon2 93 civic d16z... NITROUS???
My ? for you is how much nitrous is safe in a 100% stock d16z motor? I have re-built the head within the last year or so, using new head bolts(honda) of course... I am hearing mixed opionions... I'm hearing any n2o will streatch stock head bolts and warp the head, and im also hearing that i can throw a 75 shot at this thing without a problem... I have a venom vcn-2000 kit. This kit is all computerized. I can control the time of spray, how large of a shot, and when it sprays i.e. throttle position, and rpm. The system is a dry shot, which has a harness going to each injector to pulse them longer to richen up the mixture... it taps into the tp sensor, distributor, and the o2 sensor. The system is made to shut down automaticly if it senses a lean condition Im running sunoco 93 octane in it. I have sprayed it with approx. a 50 shot probably like 20 times already... only from 4.5k to about 7k then shift and do it all over again haha
Old 05-03-2009, 08:53 AM
XKINGX's Avatar
Default Re: 93 civic d16z... NITROUS???
I would throw 75 at and see what happens. anything can happen when nitrous or boost is put into play so its hard for someone to tell u what will happen. I have shot 150 plus on stock engine with no problem. I have also seen 50 shots go terribly wrong for other people. sounds like u have a good kit so just see where it takes you.
Old 05-03-2009, 09:04 AM
bsk211105's Avatar
The only prob. Is that this is my daily driver... If something does go "terribly wrong" im effed right in the rear haha I need my car, and i want it to be fast... I plan to build another d16z with forged pistons and nicer connecting rods ect. but finances are holding me back for now... I'm hoping someone has some experience with spraying stock d16's...??
Old 05-03-2009, 09:13 AM
XKINGX's Avatar
Thats what Im telling you. Just because my experience turned out good doesnt mean yours will. We could have the same engine, same nitrous kit,same everything and still mine could blo where yours run forever. There no one that can tell you what your engine can hold and still be safe. You dont have a wideband Im sure so read your spark plugs and see how they look. If this is your daily driver you might want to hold back on how much you try to squeeze out of it until your pocket book is fatter.
Old 05-03-2009, 09:15 AM
XKINGX's Avatar
Dont get me wrong Im all for big horse power. My daily driver has almost 600hp but its built out the ***.
Old 05-03-2009, 09:19 AM
bsk211105's Avatar
agreed. no i don't have a wideband as of now, but the computer for the venom kit taps into the o2 sensor. I have a display from the kit that tells me my rpm, my mixture, tps reading, and pulse width on my injectors, so im kinda just watchin my mix when i spray.. Have you heard of any issues with head bolt stretching?
Old 05-03-2009, 09:21 AM
bsk211105's Avatar
also, you said you have seen fifty shots go terribly wrong? Do you remember what happened to these motors? and why? I'm thinking im pretty safe with the fifty shot tho, considering the duration of time that im spraying, and the fact that i havent blown it yet after spraying atleast twenty times...?
Old 05-03-2009, 09:27 AM
XKINGX's Avatar
If your reading off the stock o2 your reading off a narrow band not wideband. I would guess you would be ok running the 75 shot in the rpm range your are running. It seems like your running safe. just put the 75 shot in and see what happens. if the ar dont like it go back to the 50.
XKINGX's Avatar
I dont think u need to worry about the head bolts at 50-75 or hell even 100
Old 05-03-2009, 09:34 AM
bsk211105's Avatar
Thats what i thought, but some 19 year kid that thinks he's a real ricer has me freakin out haha... I'll try the 75 and see what happens, I'm just praying not to reach the point of catastrophic engine failure lols... Thanks for your help, and any suggestions on engine upgrades to make this safer would be much appreciated
Old 05-03-2009, 09:44 AM
XKINGX's Avatar
forged pistons,rods, and a good tune would help allot. I prefer boost over nitrous but each to there own.
Old 05-03-2009, 09:47 AM
bsk211105's Avatar
is there a such thing as billet rods for these motors? i like boost, but its constant beating on it... i had a turbo kit, but i copped out during install... sold it to a friend thats gonna run it in his 95 ex... I like the choice of boost or n/a, thats why i went with the nitrous
Old 05-03-2009, 09:48 AM
bsk211105's Avatar
any specific brand of pistons / rods that perform best to your knowledge? How much power can the stock bottom end handle?
Old 05-03-2009, 09:52 AM
XKINGX's Avatar
Im sure u can get billet rods for the single cam. boost is not constant beating. your only in boost when u want to be just like nitrous. nitrous runs out then u gotta go pay 40-50 buks for a refill. nitrous had allot of things to go wrong such as solenoids breaking down, temp of bottle, trash in the lines, blah blah and blah.
Old 05-03-2009, 09:53 AM
XKINGX's Avatar
I prefer cp pistons and manley rods. i dont know the limits of a single cam block. I only run dohc.
Old 05-03-2009, 09:57 AM
bsk211105's Avatar
ok thanks again man
Old 05-03-2009, 10:42 AM
bsk211105's Avatar
im goin for a run with a sixty shot... hope all goes well... then i'll try a higher shot
Old 05-09-2009, 05:06 PM
bsk211105's Avatar
Ok so i'm running a 60 shot through my d16z, and i know im supposed to knock down the timing a few degrees... any one know exactly where i should set it? and also, I'm still on the stock plugs. I know i should be running 6's or 7's... Anyone know a good NGK part number for the plugs i will need???
Old 05-09-2009, 07:08 PM
XKINGX's Avatar
just retard the dizzy 1 degree. i believe the rule is 1 degree for every 50hp.
I dunno the ngk number but get one step colder then stock
Old 09-14-2014, 08:16 PM
trip0six's Avatar
Do you still happen to have your VCN-2000? I'm looking for the software and willing to pay for a copy. If anyone has a copy please email me at trip0six@yahoo.com thank you
kingrd
07-09-2005 11:00 PM
Griff
07-16-2004 11:36 AM
99civ
10
07-06-2004 11:32 PM
4nmusle
10-03-2003 10:27 AM
integranator
12-22-2002 02:58 PM
Quick Reply: 93 civic d16z... NITROUS???
