'93 Civic CX wiring to '95 B16A DelSol?
OK, I've done this before and didn't have any problems. . . . the swap went fine. I used a '94 Teg LS engine wiring harness so I didn't have to wire in the four wire O2 and wired in the Vtec switch, Vtec oil press. land Knock senser. By the way, the car has a '93n EX cluster in it(I didn't put it in). Well, the problem I'm having is that with everything hooked up the "CHECK ENGINE LIGHT" comes on. So, I reset the ECU and start it again, comes back on. So, I check for codes, the connector under the dash on the pass. side. Well, the c/e/l stays on. So, I do step one again, comes back on. recheck all wiring and make sure that all is connected(they are). Reset, c/e/l, Try to check code, it just stays on. . . . does anyone know what that can be? I even tried to put another ECU in it and it does the same thing. I can't check codes. The light just stays on. It doesn't blink at all. . . HELP please. . . . .
Re: '93 Civic CX wiring to '95 B16A DelSol? (WykidEG6)
explain the process you are using to check the codes....just want to make sure you didn't miss a step....same thing happened to me during my first attempt.
Re: '93 Civic CX wiring to '95 B16A DelSol? (eg6_LHD)
To check c/e/l codes you turn off the key and right above the ECU is what I call the code checker port. The plug with two wires going to it. You stick a jumper in it and turn the key to the on position. Then you whatch the c/e/l to see how many times it blinks. Well, it doesn't blink! And the ECU I'm using is out of a '94 DOHC DelSol 5spd.
Can anyone help?
Can anyone help?
New User
Re: '93 Civic CX wiring to '95 B16A DelSol? (EJ1)
Matt McGoldrick's did that on his Prelude, Jay. Honda told him that the ECU was bad... But we all know how shitty the dealers are. $750 for a new VTEC Prelude ECU...
hey jeremy when do you want me to come by again so we can check this out. so you can get your $. thanks for helping me with this if i didn't thank you already. oh yeah another thing, my battery was bad so do you think that could've affected it. the battery died on me yesterday, but luckily i had another laying around in the garage.
Re: '93 Civic CX wiring to '95 B16A DelSol? (rookie2nr)
No, that wouldn't do that. . . . .trying to think. . . . . come over when it stops rainning. . . .
how about saturday during the day if its not raining
[Modified by rookie2nr, 11:14 PM 12/12/2001]
ej2 coupe
11-22-2007 05:43 PM
dinko
17
07-10-2006 09:20 AM
scaredoftheCRX
02-04-2003 10:15 PM
