92 si hatch/B16a3 swap turbo questions - can i use ram or do i have to use cast one?
i got 92 si hatch and i got b16a3 to put in it and i wanted to keep powersteering and i was not sure if i could use ram manifold and do i need passanger side down pipe or what. not sure how it works first turbo built. i using t3t4 turbo and rest i didnt buy since i not sure if i need pass. side and can i use ram or do i have to use cast one.. thanks in advance
Re: 92 eg turbo questions
Re: 92 si hatch/B16a3 swap turbo questions - can i use ram or do i have to use cast o
Sweet. n the down pipe has to be pass. side right n the turbo inlet going to face toward p.s but under it.
The Grumpiest
Then any ramhorn is just for looks at that point. You can get a nice log manifold from Pfab or GoAutoworks. I've heard even the cheap Ebay variety cast ones are okay to use but make sure to get the ones where the wastegate (if you're using an extenal) mounts in the center of all four runners to prevent boost creep.
DroppedIntegra
06-20-2002 11:17 AM
