92 eg manual window regulator help.
my window(passenger side) came of the frame of the door where its suppose to sit. i took of the window and checked the regulator.the regulator does not sit straight like it does on my driver side door.i tried bending it but when i realine the window to the frame the window seems to pop out more as i roll the window up.should i just buy a new regulator or will the window still not line up straight?
Re: 92 eg manual window regulator help. (BlueIntegraBoy)
Time for power window conversion!! This happened to my brothers civic b4, i jus took the wondow off and inspected everything and put eveythin back in place and no problem since. Then my sis civic did it but her regulator was fucked. had to buy one from the dealer. 100 buck! so it might be worth for a conversion if you wanna try it. gl
Re: 92 eg manual window regulator help. (manueliscool)
i should try the conversion.but i first will try to re-install the old regulator and see what happens.
turbotuner
05-31-2010 09:27 PM
import-tooner
03-03-2010 04:19 PM
strictly.business
15
11-28-2006 11:20 AM
