92 DX hatch, ls vtec, fields vtec controller, new water pump and oil pump, not restarting.
when i started working on this hatch, there were two wires that were completely disconnected near the ecu. i think these are the OBD jumper wires. one is brown and one is green with a white stripe. these were located in the spot where the jumper port normally is, i think the owner cut the plug off in order to make it easier to diagnose codes.
issue 2. there were two wires disconnected from the ECU. of the three plugs, one being a 26 pin, one a 16 pin, and one a 22 pin, the first was on the 16 pin. looking at the plug as though it runs straight into the ecu, this would be pin 10, located on the bottom row, 5th from the left. color of the wire is yellow with a blue stripe.
the other wire is on the 22 pin connector. again, facing the ecu, this would be pin 11, top row, 6th spot over from either side. color of this wire is a solid baby blueish green.
the car is trying to turn over, not quite able to fire up. going to go check for spark and fuel. thanks for any help.
Re: 92 DX hatch, ls vtec, fields vtec controller, new water pump and oil pump, not restarting. (wrec
disconnected two wires that were originally apart, no change.
CivicxTree754
04-27-2011 11:51 AM
yusoslo
08-18-2004 10:25 AM
fasterthenmost
03-19-2003 12:37 AM
