92 D16 Low/bad Idle - HELP!!
Hey Honda Tech..
I have a 92 civic with a D16 turbo. Built motor, 9lbs boost, Hondata s300 engine management.
My idle has been very low, and fluctuating.
I am not sure what to do....
Today I took off the IACV, FITV, and throttle body, i cleaned them all really good with a tooth brush, rags, and carb cleaner. and put everything back on. It didnt change the idle at all! i dont know what to do anymore and am getting frustrated.
Vid - sorry really shitty.
http://www.youtube.com/watch?v=yafb7...el_video_title
Vacuum - when i open the throttle, vacuum drops, and when i close the throttle it dips down.... This is also proportional to my RPM dipping down almost to 0 at the same time.
http://www.youtube.com/watch?v=MymYb...el_video_title
Low idle - Car was warmed up for 10 min, throttle was untouched.
Idle after a drive
Can anyone shed some light on what i can do to fix my idle??
Idle after a drive
Re: 92 D16 Low/bad Idle - HELP!!
what does the ignition system look like? when were the spark plugs, plug wires, cap and rotor last replaced? have you tried setting the base idle and timing yet?
No I havent tried setting base idle yet. How do you go about that?
you know my 93 civic si was going the same thing so i just adjust the throttle cable and it pritty much fixed it for the most part it still does it after it warms up sometimes not very often but also i have heard that not having your coolent lines right would cause a bad idle
Fixed it! Had to adjust the throttle body stopper screw a bit.
idle is About 800rpm and steady now!
here is what I did. Grabbed a 7mm socket/wrench, unplug IACV, tighten up the TB stopper a bit, till revs were about 700. Plug back in IACV. Turn off car. Unplug battery for 10 sec to reset the ****.
And it works! My idle seems really good.
Thanks for all the input guys!
JDMguyss
09-02-2006 02:19 PM
