92 Cx cruise control?
Re: 92 Cx cruise control? (BADEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 »</TD></TR><TR><TD CLASS="quote">i imagine if its there it should work check your fuse box for a cruise control fuse.
hehe you have tiny little girly fingers </TD></TR></TABLE>
haha thats my neighbor pointing at it for me...i have pretty big hands..
where would that fuse be and what would the am be?
hmmm.. Just look under your hood, driver side, to see if you have the black box for cruise control...along with the cable running through it. If there is none present, all you have is a CX with an Si/EX steering wheel.
be professional
Re: 92 Cx cruise control? (QuikJaysun)
Probably just has an EX/Si steering wheel. Check under the hood for the cruise unit, as others mentioned - it should be a little black box positioned directly over your driver's side engine mount.
You also have a clock, which was not standard on the CX (optional accessory piece).
Re: 92 Cx cruise control? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Probably just has an EX/Si steering wheel. Check under the hood for the cruise unit, as others mentioned - it should be a little black box positioned directly over your driver's side engine mount.
You also have a clock, which was not standard on the CX (optional accessory piece).</TD></TR></TABLE>
interesting...is that button for cruise control? or what is it for? the one being pointed at
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuikJaysun »</TD></TR><TR><TD CLASS="quote">
interesting...is that button for cruise control? or what is it for? the one being pointed at</TD></TR></TABLE>
Yes, that is a cruise button.
Anyone have a pic of what i'm looking for under the hood? either in the fuse case or the cc component?
It seems wierd that they would have the wheel, the button, and it not actually work...
thanks for your help
<still a noob
<still a noob
no.....
ok so why would they put the button in? would it normally come with a cx?
it has a female part but no wires inserted...could i hook this up?
I hate not knowing everything about my car
honda-tech
honda-tech
CX's don't come with cruise control, or that clock in the picture either. you can find the male inserts for the buttons at the junk yard. the person who had the car before you half did all that, they did the easy part and saved all the wiring for you.
i have a cx also.
i have a cx also.
nk2k2
11-06-2005 12:53 PM
