'92 Civic Sway Bars?
So I've had my '92 Civic Sedan for about a year now, and after a GSR swap and some other minor stuff, I'm starting to finally take notice of the suspension. On other cars that I've owned, anti-sway bars are a typical upgrade. But on my last oil change, I took notice that there was no sway bars on this car.
What would be the typical upgrade for this car instead of thicker sway bars to reduce body roll?
Re: '92 Civic Sway Bars?
Bump! No one? Or is there a simple link about suspension upgrades? No sway bars? What is the 411 on EG Civic sedan suspension, and I'm not talking coilovers or bushings.
Seagull Management
Add sway bars, you can get them from a '92 - '95 civic EX sedan (only 5th gen civic to have both front and rear swap bars, Sis and EX coupes both have a front sway bar) You can also get them from a '94 - '01 integra, remember that whatever you take the from you also need the lower control arms from the donor vehicle as well as the brackets and end links.
One thing to take note of is to not run anything bigger than a GSR rear sway bar on the rear without the support brackets. I've seen instances of the sway bar tearing out the mounting brackets.
57IAL_Lyle_Civic
Suspension & Brakes
12-08-2007 02:37 PM
Si Arn
49
05-03-2004 09:59 PM
BNavZ
15
02-19-2004 08:20 AM
