92 civic si throwing code 21. need help!
i just read the CEL and it is throwing a code 21, vtec spool solenoid valve. was wondering what could be the problem or do i need to replace anything. this is for a 92 honda civic si.
Re: 92 civic si throwing code 21. need help! (EGnewbie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGnewbie »</TD></TR><TR><TD CLASS="quote">i just read the CEL and it is throwing a code 21, vtec spool solenoid valve. was wondering what could be the problem or do i need to replace anything. this is for a 92 honda civic si.</TD></TR></TABLE>
have you messed with it lately? is this a swap project? if none of thee above, try replacing the seals and screen. there is a little screen type filter for the oil. sometimes this gets clogged and needs replacing.
Re: 92 civic si throwing code 21. need help! (philosofy1)
yeah, recently just finish swapping a d16z6 motor in a vx hatchback. the seals and screen is from the vtec solenoid?
i took out the vtec solenoid and wipe everything. the filter is clean and not clog, but still throwing the same code. do i need to fill up the oil?
budgetb20
08-19-2004 01:49 PM
