Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Why is My Suspension Clunking?
Guide to diagnose trouble and recommended solutions
92 civic: right side suspension makes clunking noise, what is this??
Ok I'm in North Ohio = crappy roads. My 92 dx has 140k mi, has been lowered 1 5/8 for a year (tokicos & coilovers). put 16" rims w/ 205-45-16 on a few months ago. in the last month when i go over bumps in the road at any speed above 5 mph, i hear a loud clunk/knock like something is loose or worn out, coming from the right rear. well i had a bad wheelbearing on the right rear so I replaced it and also replaced the main right rear bushing w/ energy suspension one. the noise is still there and now the front right is doing the same noise. it almost sounds like the wheel is loose or a major piece of the susension is about to be falling off. Lugs and suspension bolts are all tight. I am not hearing any wheelbearing noise anymore so it is not that. and it is only the right side of the car..... any ideas??
thanks
thanks
Re: 92 civic: right side suspension makes clunking noise, what is this?? (teal_dx)
It sounds to me as if your strut has gone bad. Usually when you have a clunking noise when going over bumps this is what it is. See if you can push down on the back of the right side of your car. If that is where you hear the noise coming from. Then try the left side. If the right side is easier to push down and makes a noise then most likely that is your problem. This is just a suggestion but worth a try.
Re: 92 civic: right side suspension makes clunking noise, what is this?? (POS Hatchback)
I'm guessing rear trailing arm bushing
Re: 92 civic: right side suspension makes clunking noise, what is this?? (chainsaw)
could be your muffler/exhaust is hitting something.
Re: 92 civic: right side suspension makes clunking noise, what is this?? (underpressure (wtbimport))
Re: 92 civic: right side suspension makes clunking noise, what is this?? (Panda EK)
my front passenger side does this too, i had a bad wheel bearing and replaced it, then replaced some ball joints and outer tie rod, still does this. Could it be a lil bit of play in the inner tie rod? i mean there is about 1-2 mm of play.
Re: 92 civic: right side suspension makes clunking noise, what is this?? (Soulracer)
my del sol have this sound also, same place, right rear..........i still can't figure out wtf is wrong
it feels like the right rear is moving left and right, clunk clunk clunk
[Modified by intezn, 1:00 AM 11/19/2002]
Re: 92 civic: right side suspension makes clunking noise, what is this?? (intezn)
I figured it out, I had checked all bolts on the underside of the car and the 2 black bolts that bolt thru the wheel well at the top to hold the shock on. However I had not checked the bolt that screws onto the strut rod (?) at the top cause i didnt have an allen wrench. Well the right front was a couple turns loose, the right rear was tight but i torqued another 1/3 turn out of it. All wobbling clunky noises are gone Thanks for everybody's suggestions!
woah woah woah
its MOST LIKELY the threaded part of the coilover wiggling around and hitting your tokicos....(sorry dont know the correct term)
remember when you put the threaded tube piece over the shocks? they gave you some rubber o rings to go around the shock so the coilovers fit snug...what might of happend is the o ring moved (like mine did) so that your coils dont fit snug around the shocks, so they can rattle while your springs flex
it really does no harm if this is the case, just go to a hardware store and buy like 4 o-rings for each shock.....then your coilovers will sit snug and still have some play without that clanging clunking noise
(haha DOH, must read all of the thread before i post next time) YAY!!!!!
[Modified by iTAKEthe5th, 2:25 PM 11/19/2002]
problematic
09-10-2008 07:19 AM
