92 CIvic Hatchback Steering wheel removal(NEED HELP!!!)
Location: WTF DC Racer No Way Turbo Washington., DC, USA
I have gutted my car out completely minus the dashboard and steering wheel. How do you take the steering wheel out with keeping hte airbag.
LEt me know.
LEt me know.
Re: 92 CIvic Hatchback Steering wheel removal(NEED HELP!!!) (Civicdrgrcr)
LEt me know.
LEt me know.
Shawn
take out the little covers on each side of the steering wheel, a small on on the left and the one that covers the cruise control. then you take out the cover on the bottom of steering wheel. when you take that out disconnect the yellow plug for the airbag. then all you need is a 19mm socket and you almost done.
Just did this this afternoon
Re: 92 CIvic Hatchback Steering wheel removal(NEED HELP!!!) (Astig00)
I saw one little cover right behind the steering wheel and one to the driver side of the steering wheel. I know theres a bolt behind the steering wheel. But can't figure out how to get it out. I unplugged all the stuff already. I've taken them out non-air bag steering wheels before.
after u unplug everything and jumper the airbag so it wont go off accidentally, look on the left and right where those little plastic covers are. if u have cruise control buttons on the steering wheel, u have to take off the cruise control buttons. one u have the left and right plastic pieces off, look inside and u will see two torx screws. u can find them at most hardware stores. i forget the exact size tho. take out the torx screws to allow you to seperate the airbag unit from the wheel. now you have access to the nut holding down the wheel. if you have a lug wrench with multiple sizes (the ones shaped like a "t") one of the sizes may fit. this is what i used and i found it much easier than using the ratchet or wrench. once the nut is all the way off u can pull/slide the wheel off the splines towards u. make sure the wheels and steering wheel and lined up straight before u remove the wheel to make it easier for you when u put the wheel back on. good luck
-alan
-alan
Danielsb20crx
39
01-06-2013 01:02 PM
