92 civic hatch - dash lights won't come on..!
well just as the title said..! the inside dash n all wont work..! it comes on once n awhile but now it just died..! and dont noe wat happened..! i change the cluster, check all the fuse and idk wat happen..! someone with info or happen to them before.. please help me out..! thanks..!
Re: civic inside dash light wont come on..!
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
Are you also having problems with the taillights? If not, pry the dimmer switch out of the dash and connect the red wire to the black wire terminal in the connector with a jumper wire. If the lights now work, replace the dimmer switch.
osseau
09-07-2017 08:07 AM
DARS_C_C
01-09-2010 10:00 AM
