92 civic dx cat coverter bolts?
if you look at this link it shows some bolts:
http://www.rockauto.com/info/Bosal/D...l?03808914.jpg
it shows the down pipe to cat bolts which are spring and bolt.
but i need bolts from the cat to res/mid pipe.. i cant seem to find where to buy these bolts or which size they are..
Anyone got anymore info on the cat to resonator / mid pipe bolts?
Re: 92 civic dx cat coverter bolts?
You probably should buy them from your local dealer.
92 Civic hatchback or sedan?
http://www.hondaautomotiveparts.com/...EXHAUST+SYSTEM
93 Civic hatchback or sedan?
In the link I quoted from Ron's post, you need parts #5 and #37, three of each, assuming you do have a sedan.
18176-P08-003 005 003 BOLT, CONVERTER $8.09
90212-SA5-003 037 AR NUT, SELF-LOCK (10MM) $0.37
hm ok, thanks alot for your help.. i cant get away with using bolts from hardware store? 8$ bolt is rather expensive! If not looks like i ll be ordering those soon.
You could use a bolt from a local hardware store with the correct size washer, but good luck finding one. Before I ordered the proper bolts, I ended up using three washers cascading in size to fill the hole adequately.
