92 civic d15 non vtec intake manifold swap to d16y8 intake manifold
Old 06-19-2012, 04:07 PM
99civic4dr's Avatar
Default 92 civic d15 non vtec intake manifold swap to d16y8 intake manifold
ok so I have a y8 intake manifold and I wanted to put it in my 92 civic dx with a d15 and the y8 manifold doen't have a spot for Intake Air Temp (IAT) sensor can I run without this? I have seen the IAT sensor relocated to the intake arm will this work? and can I use the d15 throttle body and injectors
Old 06-19-2012, 04:25 PM
The Grumpiest
grumblemarc's Avatar
Default Re: 92 civic d15 non vtec intake manifold swap to d16y8 intake manifold
No you cannot run without it. Mount it to the intake.
Old 06-19-2012, 04:32 PM
99civic4dr's Avatar
so drill holes into the intake arm and bolt it down right
Old 06-19-2012, 05:47 PM
Technical Hero
HondaPartsHero's Avatar
No can't run without it.
Yes, just tap some holes for the screws and for the IAT to insert in
Yes
Old 06-20-2012, 02:58 PM
99civic4dr's Avatar
ok so I put it in today and it runs great but when u first start it the car will idle really low 100-200 rpm but once u lightly tap the gas pedal it will go to 1k rpm and stay there and run perfect any ideas do I need a ex ecu still using the dx one
Old 06-20-2012, 03:30 PM
The Grumpiest
Check the throttle cable.
Old 06-21-2012, 11:28 AM
99civic4dr's Avatar
ok got it fixed I forgot to bleed out coolant system had a whole bunch of air in it and now it runs fine I also noticed alittle more throttle response or is it just mu head playing tricks on me
Metal Head
07-20-2008 04:38 PM
redracer1024
11-11-2005 10:42 PM
Bense
11-09-2005 05:16 PM
Toptul_Honda
01-11-2003 09:11 AM
Quick Reply: 92 civic d15 non vtec intake manifold swap to d16y8 intake manifold
