92 civic cx, trying to go b series swap I know it is in the forums I have searched
I have 92 cx hatch, I am in need of some help. I am going to put a b series in the car I have already had this swap in a ef 89 civic I already know about wiring and dizzy for obd1 just need the following info.....thanks
1 what mounts I heard I can use stock mounts and just need a 94-01 teg rear bracket for the rear mount ... 2 what linkage can I use the linkage there or a teg 94-01 or ? 3 what axles, what hubs, I have ls axles and hubs from a 92 teg, |
Re: 92 civic cx, trying to go b series swap I know it is in the forums I have searched (4gencivicef9
is it a hydro or cable tranny? if its hydro then its a direct swap. you will need 94-01 integra mounts including the driver side bracket that bolts to the engine. axles im sure you can use the 92 integra but you will hav eto use the halfshaft too. as for the hubs, you are fine just keep the stock civic ones
cable trans
ditch the cable trans and get a hydro b16 tranny, or else you gotta get the hydro to cable conversion
what trans is better the b16 or the gsr
b16
