92 Civic cx hatch, no dash lights, good fuses, any ideas? Help!
Hello all.
I just bought a 1992 Civic cx hatch and i have no dash lights. I have checked all the fuses and they are all good. Everything else seems to work just fine but the dash lights, any ideas? I do have power at the dimmer switch on the two outer terminals if that means anything. PLease help, night driving stinks!
Thanks
Paul
Thanks
Paul
Re: 92 Civic cx hatch, no dash lights, good fuses, any ideas? Help! (EGJason)
Hello ,
It is the whole dash, no instrument lights, no panel lights, no nothing.
ideas?
Thanks!
Paul
ideas?
Thanks!
Paul
Re: 92 Civic cx hatch, no dash lights, good fuses, any ideas? Help! (BlueIntegraBoy)
Yeah the bulbs, or LEDs in my AC/Heat control unit burnt out, but the rest of my/dash was ok.
Hello, yes the radio works, but it is an aftermarket radio the previous owner put in, not the stock radio...
Thanks
Paul
Thanks
Paul
Re: 92 Civic cx hatch, no dash lights, good fuses, any ideas? Help! (tr6lover)
i had the same problem , and changed the dimmer switch.
thats what it was , a bad switch.
good luck
good luck
Re: 92 Civic cx hatch, no dash lights, good fuses, any ideas? Help! (95slomocivi)
Yeah go to your local junkyard and get a new dimmer switch first, before you start chasing wires around. Check if it's even plugged in at all.
Ok, Ill do that, sounds too easy but i guess it makes sense. Ill try that monday morning and ill let you all know what happened. I hope thats it!
Thanks again guys!
Paul
Thanks again guys!
Paul
i was racking my brains trying to figure out why my dash lights wouldn't work and it surprised the hell ou tof me to find out it was the switch.
does ur license plate lights work? if it doesnt, it could be the DRL... check that. i just fixed mine!
Re: 92 Civic cx hatch, no dash lights, good fuses, any ideas? Help! (j_kevin_ca)
Yeah the dimmer switch or your emergency light switch can also cause some parts of the dash to not light up.
Hello,
Yes the license plate lights work just fine. Would the DRL couse a symptom like this also? How would you test it to see if thats the problem? Thanks
Paul
Paul
Re: 92 Civic cx hatch, no dash lights, good fuses, any ideas? Help! (YodajdmEK4)
As far as the emergency light switch goes, do you mean the Hazard switch?
Thanks
Paul
Thanks
Paul
ah.. i see, then its not the DRL then... if the DRL isnt working, then ur parking, tail and license plate wont work at all..
Hello all,
I got a used dimmer switch at the junkyard today and it fixed my problems right up! Thanks again for all your help , this forum is invalueable for help on fixing problems!
Thanks a million again!
Paul
Paul
osseau
09-07-2017 08:07 AM
neb11ihtut
07-19-2007 12:29 AM
Jonathan_ED3
11
08-25-2005 03:47 PM
