92 Civic boosting, need to change injectors??
I have heard quite a few people say yes and quite a few say no.
I am wanting to boost my 92hatch with a d15 stock. I am wanting to run about 6-8psi. I have DSM injectors and a resistor box, but not 100% sure how to wire it all up. Do I HAVE to change injectors or will the stock ones run 6-8psi fine?
Re: 92 Civic boosting, need to change injectors??
the stock injectors will support about 200whp. i would jump up to some 310's or something a bit bigger to be safe
I took way too long
You will need bigger injectors to be safe.
Check out manufacturers life Precision, RC, and more.....
http://www.phearable.net/shoppingcar...tors-c-30.html
http://www.spoolinperformance.com/fu...1dd40b55c6a1a5
I took way too long
Here you go buddy. And yes, def take the time to put the 450's in. And solder your connections, no butt-connectors/ghetto/jank stuff!
https://honda-tech.com/forums/forced-induction-16/official-injector-resistor-box-install-56k-buy-broadband-517274/
okay, I will look at it tomorrow, but may still try and find someone else to do it heh. Says you live in central Indiana, where abouts there?
use prelude dohc vtecs 97 up only!!! .. they are 290cc's... and will work fine no resistor box, no nothing just install..
stockhatch91
11-22-2004 03:59 PM
