92-96 Prelude seats into 92-95 Civic
OK, I've received several questions about this, and also seen a few different posts, here is how I did it (and I used teh stock prelude seat pans/sliders/rails)......
Here are pictures of the bolts that hold the rails/sliders to the car, these are all of the drivers seat, passenger will be the same, but reversed....
This is the front inside bolt on the drivers seat, I had to enlarge the hole using a drill for this one to line up:
This is the front outside bolt (closest to door sill) this one lines up fine:
This is the rear outside (closest to door sill), and this one I still need to address. You can do 1 of 2 things here. You can drill a hole into the floor & bolt it down & go. I don't like the idea of drilling through the floor, so I will be cutting the piece off of the stock Civic rail that lines up here, and I will weld that to teh Prelude rail so that it lines up just right:
This is teh rear inside bolt (closest to console) and this one lines up fine:
I hope that this helps clear things up some for some of ya'll.
Re: 92-96 Prelude seats into 92-95 Civic (Russ713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Russ713 »</TD></TR><TR><TD CLASS="quote">use a small piece of angle bar to solve the problem on that one location. Use at least grade 8 bolts to finish up.</TD></TR></TABLE>
That's an idea I had. Make a bracket, but i wasn't sure what material would work best.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bizzzzzz »</TD></TR><TR><TD CLASS="quote">
thanks a bunch.</TD></TR></TABLE>
Hope that helps.
Hope that helps.
dAng!
Re: 92-96 Prelude seats into 92-95 Civic (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">
Hope that helps.</TD></TR></TABLE>
you can buy a piece of angle bar at a local hardware store. Then just cut off a small piece about 2" in length, drill holes, and bolt everything up. (you may have to widen up the angle by bending it after you're cut a small piece off to fit perfectly)
greebler
29
11-25-2012 04:08 AM
mr.wong
07-17-2002 08:13 PM
