92-95 vtec wiring help wanted and despiratly needed
ok here we go this is a multi parter
1 what wires would need to be changed out if your going from DX wiring harness and putting in a Si computer and engine
2 where do those wires go ar at least what are they called and what color they are on DX harness
3 i have a code for my check engine light its code 21 i believe thats a vtec wire which one is it and where does it do name color pin n e thing helps
thanxs in advance
thanxs in advance
New User
Re: 92-95 vtec wiring help wanted and despiratly needed (crazydude75927)
http://tech.hybridgarage.com/tech/5gtech/index.html
Can't perfectly explain your situation, I don't want to give false info. Might be better to try hybrid fourm. Use this link to get your info, can't find my cel code url, sorry. Good luck.
[Modified by w00t!, 5:26 AM 1/15/2003]
Code 21 = solenoid check. Need to wire from the the spool valve to A4 at the ecu.
Code 22 = presure check. Need to wire fron the little Aqua green sensor to D6 at the ecu.
Then you need a ground
Re: 92-95 vtec wiring help wanted and despiratly needed (tommyboy)
i will be doing similar..... d16z6 head and p28 on 95 dx. rather than just throwing the wires, im plannig on an ex/si harness that has the vtec wires already installed... EGs have 3 plugs on the shock tower pass side.... from there to the ecu, are the vtec wire, and vtec pressure wire already thrown or will i have to hardwire it from there to the ecu???? thanks.....
sorry for threadjacking!
Re: 92-95 vtec wiring help wanted and despiratly needed (nerdsports)
Sorry if this doesn't make much sense but I'm falling asleap. If you have any quesions just e-mail or pm me and I'll get back to you tomorrow.
-Tom
If your doing a mini me swap its going to take a little more than wiring.
how is there more than wiring? thats exactly what im doing... i thought it was just vtec solenoid wire (green-A4) and the vtec pressure wire (????-D6)... what else is involved? according to what i've read its just slap the head on and do the wiring... thats all....
http://crx.honda-perf.org/articles/z6swap/z6swap.html
singlecamcrx
11-21-2004 04:51 AM
TurboBumblBee
03-02-2002 08:14 PM
