92-95 Si Speaker brackets.
I recently got a 92 civic VX and I am trying to install some speakers in the back. I have a picture of the brackets I just need to make sure those are the right ones. Can anybody let me know what all I have to buy?
Link for website to buy the correct brackets
http://www.hondaautomotivepart...ACKET
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">i got zipties holding my 6x9's in place havent moved in like a year..lol</TD></TR></TABLE>
same here
same here
Pull your pannels back there off first and look.....I have a 93 SI with no rear speakers but I pulled those covers off a while back and im pretty sure the speaker bracket is in there just no speaker and no speaker cover
Re: 92-95 Si Speaker brackets. (clint g)
no see Eg's dont have speaker mounts in the back unless they were Si's(correct me if Im wrong). The picture above is an si hatchback from majestic I wanted to know what brackets to order to make sure I can put the Si Rear speakers 5 1/4" in the back.
Re: 92-95 Si Speaker brackets. (PinkMaggit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinkMaggit »</TD></TR><TR><TD CLASS="quote">no see Eg's dont have speaker mounts in the back unless they were Si's(correct me if Im wrong). The picture above is an si hatchback from majestic I wanted to know what brackets to order to make sure I can put the Si Rear speakers 5 1/4" in the back.</TD></TR></TABLE>
This was an optional kit just like the audio console.
ive got a 93si and no rear speakers, i was like wtf, where are they, i popped out the rear cover panels on the rear large panel where like the seatbelt goes behind, ran some wire from behind the dash under the carpet, then just mounted them strait to the plastic with the little black metal clips that come with the speaker. just roto ziped some holes off the templets, if someone would tell me how to post pics, i will, it actally looks pretty badass and sounds good
Re: (EG93si)
those brackets hold 6 1/2s not 5 1/4s. If your front doors have 5 1/4s you can also get ex/si front door plates that will hold 6 1/2s. then you'll have 6 1/2s all the way around. also if you get those rear brackets the si came with different inner quarter panel inserts that has a speaker grill in it, to replace the solid one that came in hatches without rear speakers. hope this helps.
Re: (5THGENSI)
also unless your going to use the factory rear speakers or the honda optional equipment speakers(pioneer) you can go to best buy and get the metra harnesses ($5.99) that plug into the factory speaker wire thats in the quarter panel, then you dont have to cut/splice/t-tap/schotlock/tape/solder or anything else, just plug em in.
Re: (5THGENSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5THGENSI »</TD></TR><TR><TD CLASS="quote">those brackets hold 6 1/2s not 5 1/4s. If your front doors have 5 1/4s you can also get ex/si front door plates that will hold 6 1/2s. then you'll have 6 1/2s all the way around. also if you get those rear brackets the si came with different inner quarter panel inserts that has a speaker grill in it, to replace the solid one that came in hatches without rear speakers. hope this helps.</TD></TR></TABLE>
You don't need to buy the si brackets to install 6 1/2's in the front. All you have to do is cut the back out of the plastic cups that hold the speakers and then they bolt right up. This is what most stereo install shops do.
