EM1 window went off-track, AGAIN
Old 05-14-2011, 02:05 PM
Nocturne's Avatar
Default EM1 window went off-track, AGAIN
So today its like every other normal day when I'm leaving for work, I get in my car, started it up, and went to put down the windows. My drivers side one started to go down a little slower and then POP. Right after that noise I knew exactly what happened because this isn't the first or second time this has happened since last fall. I got brand regulators/tracks/everything in my doors that why I'm pretty pissed about it this time, I thought it was over. So now until I get a day off I'm stuck in this heat with my window up on my side incase it rains.
The only question I have is there really any solution or way I can make it so this stops happeneing? Any tricks? Tips? Its soooo annoying
Old 05-14-2011, 02:17 PM
Townson's Avatar
Default Re: EM1 window went off-track, AGAIN
the window in my dx has been off track for about a year solid. after i fixed it the 4th time, it did it again. so i just said to hell with it.
Old 05-14-2011, 02:47 PM
g0rg0n's Avatar
I've had this happen to me before. Just spray some lubricant down the tracks and roll the window up and down a few times.
Old 05-14-2011, 04:24 PM
confidence's Avatar
there is a TSB about it with the whole procedure for putting it back in correctly.
Its in one of the external links in the FAQ.
Personally i spray a little silicon lube into the tracks every so often and have never had this problem.
Nighthawk7thGen
Honda Civic (2001 - 2005)
09-17-2008 08:03 AM
MiracleWhip
12-20-2007 04:49 PM
bleedblue94
11-07-2006 02:48 PM
PhatBoy5015
14
05-08-2006 05:59 AM
EnKidu
10-12-2004 07:08 PM
Quick Reply: EM1 window went off-track, AGAIN
