Are 92-95 civic struts interchangable with 99-00?
Old 12-05-2008, 12:21 PM
Mr.Chow's Avatar
Icon2 Are 92-95 civic struts interchangable with 99-00?
I've heard that the springs are interchangable, but would 92-95 civic struts fit in a 99 4-door civic? also are the upper control arms interchangable as well?
thanks!
Old 12-05-2008, 12:56 PM
burningrex's Avatar
96-00 struts in the front don't have the spot to bolt up the brake line to the strut... if you're cool with that then it'll work...
the rear struts are wider where they bolt up to the rear lca you'll have to use washers if you want them to work... skunk2 uses wahers in thier strut kit for ek's... but they use thick washers...
and no you can't use the upper control arms...
hope that helps and hope it makes since
Old 12-05-2008, 01:42 PM
Mr.Chow's Avatar
thanks appreciate that!
Junaid K
10-14-2013 10:36 AM
JDM EJ2
07-03-2009 07:15 AM
killahatch
04-16-2009 06:47 PM
99_dc2
09-25-2005 10:24 AM
scdarksol
12-16-2002 06:15 PM
Quick Reply: Are 92-95 civic struts interchangable with 99-00?
