92-95 civic ex brake size same as 94-95 gsr?
Re: 92-95 civic ex brake size same as 94-95 gsr? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Yes they are... </TD></TR></TABLE>
Even the 92's?
Even the 92's?
Re: 92-95 civic ex brake size same as 94-95 gsr? (Pho Real)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real »</TD></TR><TR><TD CLASS="quote">
Even the 92's?</TD></TR></TABLE>
lol ya, believe they are 9" rotors. EX/Si/GSR is the same.
Re: (phantom_sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom_sol »</TD></TR><TR><TD CLASS="quote">i thought the integras were 10.2 inch. my del sol s is 9.5</TD></TR></TABLE>
what model del Sol do you have?
Re: 92-95 civic ex brake size same as 94-95 gsr? (shermanyang)
abs was an option in 94-95 im pretty sure they are 10.3" rotors ive never measured mine but this winter im going to do some brake work as well as some other goodies and ill have a DIY!!
Re: 92-95 civic ex brake size same as 94-95 gsr? (O.G triple O.G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G triple O.G »</TD></TR><TR><TD CLASS="quote">i believe 94-95's rotors are the same but isnt the calipers smaller then gsr's?</TD></TR></TABLE>
Yup, the rotor size is the same but the piston is larger on the integras.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">92-93 si's don't have the same size brakes. only the 94-95's do, that's when they started to put abs on the si's.</TD></TR></TABLE>
We're talking about EXs here.
Re: 92-95 civic ex brake size same as 94-95 gsr? (CXHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback »</TD></TR><TR><TD CLASS="quote">
We're talking about EXs here. </TD></TR></TABLE>
ok so the calipers are not the same but the rotor sizes are???
i have a 92 civic ex sedan if that helps... just want to know if i could upgrade using stock gsr parts unless its already the same thing
Re: 92-95 civic ex brake size same as 94-95 gsr? (StockEG9)
Correct.
If I were you I'd upgrade to 11" rotors with a fastbrakes kit or something, because really the hassle of changing out calipers isn't worth the 3 or 4mm larger the piston is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback »</TD></TR><TR><TD CLASS="quote">We're talking about EXs here. </TD></TR></TABLE>
Ex and Si aren't the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback »</TD></TR><TR><TD CLASS="quote">Correct.
If I were you I'd upgrade to 11" rotors with a fastbrakes kit or something, because really the hassle of changing out calipers isn't worth the 3 or 4mm larger the piston is.</TD></TR></TABLE>
so what is the difference between the civic ex front brakes and the civic dx front brakes?
Ex and Si aren't the same?</TD></TR></TABLE>
No, not during 92-93. The EXs had the nissin calipers in 92-93 where as the Si's didn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 »</TD></TR><TR><TD CLASS="quote">
so what is the difference between the civic ex front brakes and the civic dx front brakes?</TD></TR></TABLE>
CX/DX/LX/VX/HX have 9.5" rotors w/Akebono calipers
EX/Some Si have 10.4" rotors w/Nissin calipers. I think it's 10.4". I see anywhere from 10.2"-10.5"
EX/Some Si have 10.4" rotors w/Nissin calipers. I think it's 10.4". I see anywhere from 10.2"-10.5" </TD></TR></TABLE>
ok so same rotors just different calipers between the ex's and gsr's.. .got it.. next question is is it worth it to upgrade t gsr calipers or will i even feel a difference?
ok so same rotors just different calipers between the ex's and gsr's.. .got it.. next question is is it worth it to upgrade t gsr calipers or will i even feel a difference?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback »</TD></TR><TR><TD CLASS="quote">If I were you I'd upgrade to 11" rotors with a fastbrakes kit or something, because really the hassle of changing out calipers isn't worth the 3 or 4mm larger the piston is.</TD></TR></TABLE>
92 Si here... Nissin calipers
Sandblaster will OWN rust
Modified by B and B at 9:34 PM 9/22/2003
They changed the front brake size mid 93. Eg's that re 94 and newer have the larger front disc already. Even some 93's do also during the transition period.
Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst »</TD></TR><TR><TD CLASS="quote">They changed the front brake size mid 93. Eg's that re 94 and newer have the larger front disc already. Even some 93's do also during the transition period.</TD></TR></TABLE>
so what size on a 1992 civic ex sedan are the rotors and calipers?
