92-95 civic clock and radio HELP!!!
Old 09-08-2004, 12:37 AM
MrITR#0168's Avatar
Default 92-95 civic clock and radio HELP!!!
for some reason my clock resets to 1:00 everytime i start my car and my radio doesnt work. Do anyone have the same problem? PLEASE HELP...without a radio...it really sucks....
MrITR#0168 is offline
Old 09-08-2004, 01:29 AM
speedfreek128's Avatar
Default Re: 92-95 civic clock and radio HELP!!! (JDMhatchie128)
check fuses first then make sure clips are all tight then check wiring
speedfreek128 is offline
Old 09-08-2004, 08:20 AM
94solchick's Avatar
my radio didn't work in my hatch when I got it, I checked the fuse in the dash and it was fine...but there is another fuse under the hood for the radio...I believe it is 7 or 7.5. It's the lowest one under the hood. Try that before rewiring.
94solchick is offline
Old 09-08-2004, 08:31 AM
nocturnaldragon's Avatar
Im assuming that the clock and radio are the same thing in this case ie the clock is built into the radio? if its an aftermarket radio it sounds to me like whoever installed it did it half assed and dident wire it in properly to me. so id check the wiring on the back of the deck make sure everything is connected right and take a test light to the wires to be sure you are getting power. If its not an aftermarket deck this would tell you if the wiring is good and indicate its propably the radio that went bad on you. But there is a fuse for the memory circuit for the radio and clock on the same circuit under the dase like someone said b4 id check that too. The radio might not work if its not getting that memory feed.
nocturnaldragon is offline
Old 09-08-2004, 08:38 AM
fakemike's Avatar
Default Re: 92-95 civic clock and radio HELP!!! (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda94delsolchick &raquo;</TD></TR><TR><TD CLASS="quote">my radio didn't work in my hatch when I got it, I checked the fuse in the dash and it was fine...but there is another fuse under the hood for the radio...I believe it is 7 or 7.5. It's the lowest one under the hood. Try that before rewiring.</TD></TR></TABLE>
Same thing happened to me. Its the BACKUP fuse under the hood. Its 7.5.
Fix this fuse and it will fix your problems
fakemike is offline
Old 09-08-2004, 09:02 AM
94solchick's Avatar
Default Re: 92-95 civic clock and radio HELP!!! (fakemike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike &raquo;</TD></TR><TR><TD CLASS="quote">
Fix this fuse and it will fix your problems </TD></TR></TABLE>
yeah, word.
Old 09-08-2004, 09:53 AM
MrITR#0168's Avatar
thanks guys i'll try that tonight after i get off work. Thanks for the heads up.
Old 09-08-2004, 09:56 AM
tallblondkid's Avatar
Default Re: 92-95 civic clock and radio HELP!!! (speedfreek128)
my friend has the same problem with his clock, i thought the only way to reset the clock was to reset the battery... maybe check fuses, i dunno
tallblondkid is offline
Old 09-08-2004, 10:10 AM
just4747's Avatar
Default Re: 92-95 civic clock and radio HELP!!! (tallblondkid)
its absolutely without a doubt, the fuse under the hood...one of em thats in the fuse box..forgot which one tho....by the way..how do i become a regular member so i can post more than 5 posts a day??
just4747 is offline
Old 09-08-2004, 07:41 PM
MrITR#0168's Avatar
Default Re: 92-95 civic clock and radio HELP!!! (just4747)
THANKS!!! guys for the info...yes it was the fuse under the hood. everything works great now..
Old 09-08-2004, 07:46 PM
green-'s Avatar
2 weeks from the day you signed up, you become a H-T member, if your user rating doesn't go down or anything.
green- is offline
Old 09-09-2004, 08:52 AM
just4747's Avatar
Default Re: 92-95 civic clock and radio HELP!!! (green00EX)
nice thanks
just4747 is offline
Old 09-10-2004, 08:44 AM
94solchick's Avatar
God I'm smart
Old 08-06-2016, 05:10 PM
94CIVLX's Avatar
Thank you
94CIVLX is offline
tacpsi
09-23-2019 06:20 PM
MUGEN_EG95
Acura TL, RL & ZDX
10-13-2009 06:26 PM
scorpio1472000
11-27-2007 07:15 PM
modifyORdie
10-01-2006 07:07 AM
tfalconier
12-20-2003 07:05 PM
Quick Reply: 92-95 civic clock and radio HELP!!!
