92-95 civic climate control dim, not all lit up
i'm pretty sure this happens to alot of 5th gen (92-95) drivers out there because i had this happen in all three of my 5th gens i've had. The problem is my Climate Control unit is dim or when pressing certain buttons the lights turn on or off. I was thinking this may be a loose ground or something. I was wondering if anyone knew for sure what it was so i can fix it while the CC is out.
Thanks.
EDIT:: oh yeah i tried searching.. but only found one that led to no where... maybe i am wording it wrong.
Thanks.
Re: 92-95 civic climate control dim, not all lit up (bpkmrtoes)
i'm intresed as well i don't have any lights come on nor do i have any air coiming out of the vents
Re: 92-95 civic climate control dim, not all lit up (mini-meEj1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-meEj1 »</TD></TR><TR><TD CLASS="quote">i'm intresed as well i don't have any lights come on nor do i have any air coiming out of the vents</TD></TR></TABLE>
your fuse probably popped. My CC lights are just tripping out.
well in my eh my jdm climate control lights didnt work at all but every once in a while they go on but i found out the lightbulbs were out n i changed them n it lit up..but try checking the lights in them cuz thats what happened to me
Re: (94jdmD15Beh2)
It can also be a fuse cause that happent to me i was looking through everything till i found out it could be the fuse and it was.
Re: (94jdmD15Beh2)
yeah.... i took out the CC to change to amber bulbs in the first place, i just wanted to see if other people had something else that was causing it.
Re: (bpkmrtoes)
i had the same problem..but happened was that the bulbs were a bit too big so had to force them in there..you should take you CC out again, and try pushing them in as hard as you can, that was the only to to make mines work..also before you put you cc make sure to plug in the cc to see if they work first then put it in..just a thought hope it works for you.
Re: (ek-g6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek-g6 »</TD></TR><TR><TD CLASS="quote">i had the same problem..but happened was that the bulbs were a bit too big so had to force them in there..you should take you CC out again, and try pushing them in as hard as you can, that was the only to to make mines work..also before you put you cc make sure to plug in the cc to see if they work first then put it in..just a thought hope it works for you.</TD></TR></TABLE>
makes sense... it was a tad big... lol thanks! i'll try it out. btw, my CC wasn't bolted back in yet just in case something like this happened. lol
Re: (ShortyzKustomz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShortyzKustomz »</TD></TR><TR><TD CLASS="quote">Mine will come on if I smack the dash, 99% of the time they dont come on</TD></TR></TABLE>
^^ I have that same problem... I try and the **** out of it and most of the time it never comes on, but if I hit a bump with my sh!tty suspension they will come on *shrugs*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">^^ I have that same problem... I try and the **** out of it and most of the time it never comes on, but if I hit a bump with my sh!tty suspension they will come on *shrugs*</TD></TR></TABLE>
LOL! i knew more people had this problem. hahaha
Re: (bpkmrtoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes »</TD></TR><TR><TD CLASS="quote">
LOL! i knew more people had this problem. hahaha</TD></TR></TABLE>
Yes sir... since my radio is gone (jacked over 2 years ago) I think I may just purchase new bulbs and replace them. Maybe take a look at the wiring and make sure everything is secure.
My other problem with lights is that my dome light and trunk dome light dont work even after new bulbs... my car is a PITA.
Re: (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">My other problem with lights is that my dome light and trunk dome light dont work even after new bulbs... my car is a PITA. </TD></TR></TABLE>
mine don't either! do you think its because of the after market radio? there was this one time that my dome light came on out of no where... that was the only time though.
acmoc
03-03-2015 09:00 PM
94preludeguy
10
05-18-2014 10:03 AM
