92-95 Civic Airbag delete?
I heard you can use the 96 civic airbag delete on the EG, anyone have pictures??? or should I just buy the Password JDM carbon fiber one?
Seagull Management
Re: 92-95 Civic Airbag delete? (ImporTProphetZ)
'92 - '93 civic dash without airbag. If you want to remove the drivers airbag get a '92 - '95 canadian steering wheel without SRS.
I just went through VIN inspection so I dont want to do it again, LOL. I had a dash without airbag but it was stolen so I had to prove that I didnt steal it and I bought it like that. Was a huge hassle. I just need to remove passenger airbag.
Re: (JDM_Honda_349)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Honda_349 »</TD></TR><TR><TD CLASS="quote">Check this thread out on CC. Im actually going to do this tonight.Seems pretty simple really, 3 bolts and unplug the harness and your set from what it says on club civic.</TD></TR></TABLE>
let me know how it works out
Well I guess its just a bit different on the 92-95's cause I just did mine,I had it done in a few minutes and it was pretty easy.
First off, to make things alot easier, remove your glove box,which has 2 screws holding it to the bracket and then remove the bracket that the glove box was mounted to, which has 4 screws.Its best to remove the bracket because one of the nuts on the left side was impossible to get to because of the angle and the extension would not slip on the nut without removing the bracket.
Next, go ahead and unplug the airbag harness.Theres only 2 nuts on the peice of tubing like shown in the picture. Theres also 4 more nuts that need removed, 2 on each side of the brackets that hold it in place against the dash. You have to lay down and look up at the bottom of the air bag to see them.Once you have them all removed just ease the airbag up out and your basically finished!
I didnt have a camera of I would have taken pics and mark which screws and nuts to remove, but its so simple you can do it without the help of pictures haha.
Goodluck!
Goodluck!
Papacivic
Honda Civic (2006 - 2015)
06-29-2008 12:14 PM
cnyej1
05-06-2005 09:42 AM
