92-94 gas tank plug
On the bottom of the tank on the side like the oil pan isn’t there a drain plug for the gas? I will see when I get home, but if anyone knows I can change my plans after work
Re: 92-94 gas tank plug
:bump:
I'm thinking there isnt...
If I'm right, then just run it low on gas then drop the tank to do whatever you need to do. |
i cant drive it. its untuned like crap. i need to get all the gas out and put E85 in so we can start to tune it today or 2morow. il just syphon the gas out with a hose i think the eg didnt have the safty thing inside that keeps it from syphoning
Originally Posted by rick_rabies
(Post 39228590)
half tank. another option that will cost more $ and work is put a fuel cell next to my seat and ditch the pasnger seat and gas tank..but i just want to tune it and drive for once after a year
super. thanx. gas never tastes good. it burns my mouth like 150 proof
(Post 39229855)
update. for poeple searching for this info later on.
i got home yeah theres a plug like Jon said. to drain the gas. you cant just jak up the back end (car needs to be level or recline back) so i jack up the front on jackstands THEN i jacked up the back end(making it level) then i drained the tank into gas can i put that in the wifes jeep then i put E85 in.. :) thanx guys for all your help |
(Post 39241244)
i got home yeah theres a plug like Jon said. to drain the gas. you cant just jak up the back end (car needs to be level or recline back) so i jack up the front on jackstands THEN i jacked up the back end(making it level) then i drained the tank into gas can i put that in the wifes jeep then i put E85 in.. :) thanx guys for all your help why are you wanting to run E85? Just curious. |
with turbo. cheaper fuel more HP
