90 Honda Civic Hazard Lights electrical short
My 90 Honda Civic 1 year old battery kept dieing. I pulled the negative ground from the battery and hooked up a test light from cable to terminal, the light came on. I then processed to pull each fuse and test. I finally got the the Hazard fuse under the under, pulled it and tested, no light on tester. Hazards still seem to work right, is there something else wired to that circuit that would drain the battery?
Thanks for your help. |
Re: 90 Honda Civic Hazard Lights electrical short
you could have a bad batt even tho its new! check the voltage from batt
I have not checked the battery, yet. I will do that tonight and let you know.
thanks |
Unplug ECU connector B. Does this stop the parasitic battery drain?
If not, then also unplug the hazard switch connector to check whether the battery drain is stopped. http://i639.photobucket.com/albums/u...cture_3668.jpg http://i639.photobucket.com/albums/u...cture_3669.jpg |
