89-91 clutch in 92-95? compatability?
Old 10-01-2006, 09:34 PM
md88hfcrx's Avatar
Default 89-91 clutch in 92-95? compatability?
i have almost completed my turbo shopping list. but i need a clutch. boosting a d16z6 in my coupe.
i have a crx with an ACT clutch w/ HD pressure plate. i dont drive it so could i use this clutch in my z6?
i dont think its an '88 clutch, but its a '91 tranny if that matters.
Old 10-02-2006, 08:09 AM
CO_CReX's Avatar
it wont work because cable trannys and hydro trannys center shaft is different sizes.
Hydro is bigger than Cable.
Old 10-02-2006, 11:47 AM
D Tranny Guru
Mista Bone's Avatar
Default Re: (CO_CReX)
not on a SOHC.......
90-2000 clutches and flywheels are the same, just a different throwout bearing for the 90-91.........
Old 10-02-2006, 02:26 PM
md88hfcrx's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">not on a SOHC.......
90-2000 clutches and flywheels are the same, just a different throwout bearing for the 90-91.........</TD></TR></TABLE>
hell yeah. thanks alot. since i am not what year the block is, how can i tell?
Old 10-02-2006, 03:57 PM
D Tranny Guru
Mista Bone's Avatar
Default Re: (md88hfcrx)
block has nothing to do with the clutch
Old 10-02-2006, 04:02 PM
md88hfcrx's Avatar
so is the 89-00 the same? i heard only the 88 was different. does this mean i could use it on my z6 no matter what just switch the clutch and flywheel all together?
Old 10-02-2006, 10:57 PM
D Tranny Guru
Mista Bone's Avatar
READ.........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">90-2000 clutches and flywheels are the same, just a different throwout bearing for the 90-91......... </TD></TR></TABLE>
DId I mention 1989? NO!
Old 10-02-2006, 11:03 PM
Luserkid's Avatar
I thought cable and hydro clutches are different. Shouldnt it be 92-00 the same? What made the 90-91 compatable since they had the same cable trans as the 88-89?
Old 10-03-2006, 10:54 AM
D Tranny Guru
Mista Bone's Avatar
88 = 21 spline count, small flywheel surface, 190mm clutch
89 = 20 spline count, small flywheel surface, 200mm clutch
90-2000 = 20 spline count, large flywheel surface, 212mm clutch
Old 10-03-2006, 01:37 PM
md88hfcrx's Avatar
ok gotcha. wasnt thinking about the spline matching with tranny imput shaft. so take it out and get the spline count.
but being that the tranny came out of a 91, thus having a 20 spline count, it should work, right?
(thats why i said 89-00 in the first place, they have the same spline count. would the surface change the compatability?)
Old 10-03-2006, 07:21 PM
md88hfcrx's Avatar
bump
Old 10-03-2006, 07:27 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">88 = 21 spline count, small flywheel surface, 190mm clutch
90-2000 = 20 spline count, large flywheel surface, 212mm clutch</TD></TR></TABLE>
Wow i never knew that, and i know better then to go head to head with you (or bense) on tranny info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md88hfcrx &raquo;</TD></TR><TR><TD CLASS="quote">
With the giving information it should work.
Old 10-04-2006, 07:09 PM
md88hfcrx's Avatar
Default Re: (Luserkid)
bump anyone else? if clutch dont work i'll use it when i circle track the rex next spring.
brockscivic
12-01-2007 08:53 AM
MniMeHatch89
06-12-2006 04:45 PM
Reego.
02-17-2005 08:39 PM
gtfour43
07-16-2004 08:12 AM
jondancer
06-09-2003 02:57 AM
Quick Reply: 89-91 clutch in 92-95? compatability?
