81mm pistons in 81.5mm cylinder???
hey everyone i just picked up a b18a block and the guy i got it from said he had it a half milimeter over. along with the block he gave me a set of 81mm pistons so my question is will the 81mm pistons work in the 81.5mm cylinders with no problems? and since i wana make it a turbo motor im nervous about it
Man U FTW
Re: 81mm pistons in 81.5mm cylinder???
Just to re-affirm what everyone else said, this IS NOT going to work. Piston-to-wall clearances are much closer than .5mm and thermal expansion isn't going to make up the difference.
i'd go to the jy and buy a b18a short block out of a da. should be able to get it for around 150 if you're dead set on using those pistons. then sell the current block you have and go from there
i just dont wanna spend the money on pistons but im gonna take it to my friend at the machine shop before i do anything and if it really is 81.5 ill just get a bare block from the junkyard and use the arp bolts girdle block guard and pistons that came with this one
Man U FTW
Throw the block guard away or sell it to someone else. They're notorious for cracking sleeves by creating hotspots on the sleeve and hindering coolant flow.
