8.5.1 compression running stock, is it ok?
Im rebuilding my d16y8. got all the parts i need expect the 4bar map sensor / fuel injectors and the clips. I was wondering if i put it all back together if i can drive it with my 8.5.1 compression with oem ngk spark plugs and everything else STOCK no turbo, so i can drive it back and forth to work tell i get the injectors. it will be on the stock ecu
Re: 8.5.1 compression running stock, is it ok?
Are you rebuilding this motor for turbo? If so, the best way to break the motor in is to run it hard on a good tune on the dyno.
1 Post
Thats one theory. I broke my motor in slowly and n/a and it has been very much boosted for 17k miles now without any issues. Either way it should be fine. Mine was driven quite a while this way.
ok cool. yeah i dont plan to be racing it like this i just wanna make sure it wont get to hot and mess up my brand new pistons.
Im i gonna get a check engine light or is it gonna miss or back fire. i was told there will be extra fuel not being burned and going straight out the exhaust. just curious what to expect since this is my first rebuild.
88hbz6
11-25-2008 07:48 PM
99blackdc2
09-04-2006 07:47 PM
Sinner
01-09-2006 11:11 PM
