75hp shot
Re: 75hp shot (Blurrrrr-SI)
i have run a 60 shot on a totaly stock ex motor for about a year now.. without any problems.. your motor should hold it fine, but with any forced induction you always run the risk of breaking... so should it be able to handle it.. sure it should.. will it.. you will know the second you hit it.. lol i know that is a sucky answer.. but it is the truth.. if you still have the clutch described in your signature fix it before doing this as it will be one of the first things to go....
Re: 75hp shot (oc_civic)
With:
-2 degrees timing retard
-Colder spark plugs
-Always run at least 91 octane
You will be fine. Just make sure you use it responsibly.
-Colder spark plugs
Re: 75hp shot (Slopoke)
I am going to the 1/8 mile drag strip tomorrow and I am going to use the 75hp shot.I will post my times I think my times might be around 9.2s-9.5s.I am going to probaly screw up my clutch i think.
Re: 75hp shot (97hb)
posting on a lot of message board has help me build up a BS immunity.. you should work on building one up also.. so when you see statements like this.. "yo dawg wit ma 50 shot i took out a supra..."it is easy for you to just skip over them, and not even waste your time responding..
sloweredcivic
01-27-2004 07:21 AM
