74HC373 , i cant tell which way it goes in? help
as it says, i bought the kit from moates and i can't destingish which way the chip gets soldered in
Re: 74HC373 , i cant tell which way it goes in? help (EG93si)
you should see a little indentation in the right or left of the chip. then look atthe other chips on your ecu, and put that tab the way they are going... i will try to take pictures
Re: 74HC373 , i cant tell which way it goes in? help (dem0nk1d)
there are no arrows or half moons, just the chip serial in the middle, and a little circle just to the bottom left, its the moates kit, also is in a jdm p30 surface mount
Re: (THC07)
If theres a little dot in one of the corners thats 'Pin1', no one would ever make an IC with no identification mark, you just dont know what the hell your looking for.
edit: here
edit: here
hoffmanb16
Engine Management and Tuning
14
08-16-2010 08:53 PM
